My choice for aftermarket horn was the Stebel Nautilus Compact. Rated at 115dB at 2 meters, 139 dB at 4 inches. It has that European/Ferrari type sound. Makes sense...they're made in Italy and Stebel once upon a time supplied horns to Ferrari. Hear it:
http://www.stebel.it/stebel2009/product ... NEUMATICSA few months back I felt the need for a pointless project so I reinstalled my OEM horn. I hooked up both horns up to a SPDT toggle switch so that each horn would operate from the steering wheel but not simultaneously. Flip the switch up and you get the friendly OEM meeep-meeep. Flip it down and you get the Nautilus.**********Quote, originally posted by dqami »When you guys install your new horns, are you also installing a new horn button? My 04's horn doesn't work at all. Checked the fuse and it looks good and there's a wire from the harness hooked up to the horn. Rather than spend a lot of time and $ trying to figure it out, I just as soon put in a new horn.Another simple test that may help isolate the problem is to listen for a "click-click" from under the hood, specifically from the engine compartment fuse block, when you press and release the horn. If you get the "click-click" then the problem is most likely between the fuse block and the horn itself.A while back when the Nautilus was my only horn it stopped working. I'd press the horn and just get the click-click. As it turned out the horn's ground wire was corroded. I replaced the wire and all was good. Though in the case of a bad ground with the OEM horn, I'm not sure how that would be fixed (other than replacement) since the horn grounds itself on the mounting bolt.**********Quote, originally posted by SmAshley » I like this one lol
http://www.youtube.com/watch?v...annel That guy (airraidsiren) on youtube is my horn hero! He has quite the collection of ship horns. My personal favorite...he honks at a cruise ship and it honks back.
http://www.youtube.com/watch?v=BSVgJsQU ... *****Quote, originally posted by houseofbugs »Watch this. I laughed SO hard. It literally sounds like a train coming.
http://www.youtube.com/watch?v...latedThat is awesome!!! Sherri's hair makes the vid even better.
