Unlock liftglass with key?
mmendez72
Post by mmendez72 »
I tried to accoding to the owners manual to unlock the liftglass and tried to unlock the hatch with the key. Supposedly you can turn it but it wont work..any suggestions...?
keithvibe
Re: Unlock liftglass with key? (mmendez72)
Post by keithvibe »
press the button on your remote or inside the car next to the steering wheel
mmendez72
Post by mmendez72 »
That part works but the owners manual states that you can unlock the b
mmendez72
Re: (mmendez72)
Post by mmendez72 »
That part works but the owners manual states that you can unlock the back withe the key but the key wont work. any suggestions?
bigdaddyjosh
Re: (mmendez72)
Post by bigdaddyjosh »
I also have this issue. My key turns but does not unlock it.
Pioneer AVH-P8400BH HU Polk Audio DB-6501 Components Pioneer GM-6400F Amplifier K&N drop-in filter Fiberglass Sub box w/10" Cerwin Vega
mmendez72mm, I see you have a 2004 Vibe, You can open the glass by itself by turning the key to the lock position, then turn it the same way a little more, past lock, it will pop the glass openbigdaddyjosh, your 2009 glass won't open independent of the hatch., but if your key turns but doesn't unlock the hatch, then at least you're still under warranty. I've never touched a 09 or 10 Vibe, my 03 the hatch lock just locks and unlocks the hatch, but doesn't pop the entire hatch open, still have to press the handle to open it. I assume 09s are the same way. I don't have power locks, so I don't know if the remote just unlocks the hatch or if it pops it open too.
djkeev
Re: (joatmon)
Post by djkeev »
The remote for the power locks (2007) unlocks all 5 doors, does NOT open the rear deck lid. Another separate button will unlatch the glass and only the rear glass.Also to unlock the doors you can press once for the drivers door only or press unlock twice and the entire car unlocks.Dave
(o ! /o) (o)=I=(o)
mmendez72
Re: (djkeev)
Post by mmendez72 »
I agree with bigdaddyjosh. The key is supposed to unlock the hatch and the glass from the back when you turn it but it doesnt work...I dont know if its the lock thats the problem or the key..
VforVIBE
Re: (mmendez72)
Post by VforVIBE »
