When to replace radiator hoses???
cptnsolo77
Post by cptnsolo77 »
Its time for a coolant flush. While im in there I was thinking of replacing the upper & lower hoses as well. Any input guys? The Vibe has 92K. I know back in the day, if the hoses felt soft its time to change. Does that still hold true for modern cars?
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Re: When to replace radiator hoses??? (cptnsolo77)
Quote, originally posted by cptnsolo77 » I know back in the day, if the hoses felt soft its time to change. Does that still hold true for modern cars?I don't see why not! But why then just replace the upper/lower rad hoses... don't forget the hoses to the heater core!
jkm311
Re: When to replace radiator hoses??? (star_deceiver)
Post by jkm311 »
How difficult is this? I'm doing a coolant flush tomorrow, but it's my first one. Only 49k miles on my 2006 right now. Should I do them next flush? Seems early to replace them now.What's the earliest mileage/age of your Vibe anybody has needed to do this?
Steelies to the rescue.
Water boy
Post by Water boy »
For many years I did the upper and lower and heater every 50K or so. Then I extended it to 100K. Now.... I've extended it to the point right after I've gotten too lazy.We've always had high mileage cars so I don't know how to convert that to years.FWIW...not much help.
2008
47,891 Added new horns
69,036 Added sound deadening
70,395 Battery
Ol' Timer
Post by Ol' Timer »
Quote, originally posted by star_deceiver » don't forget the hoses to the heater core!Which of the heater hoses coming out of the Vibe firewall is the Inlet Hose. The top one? Or the bottom one??
2006 Salsa Vibe - Auto - Side Curtain Air Bags - ABS - Vehicle Stability Control - Tunes No Moon - Monotone - Preferred Package - Slate Cyper Cloth - Steelie Wheels2002 Snap Orange Beetle - Auto - Turbo
jake75
Re: When to replace radiator hoses??? (Ol' Timer)
Post by jake75 »
Replace hoses? I forgot about that routine maintenance expense. One more reason I am glad I sold my 6 year old '03 Vibe and got an '09 in 1/09. I suspect age is as or more important than miles when it comes to those hoses.I suspect the modern hoses are better today. I had a 1968 Cadillac and had to replace all those hoses after 3 years. Of course in those days that was not a major expense.
Still on the originals on my wife's '03... I need to give them a good look. Only low 60k miles on the car but a lot of years!
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
mntn-biker
Post by mntn-biker »
Anyone know if the top hose is the heater inlet hose?
2003 base model
Ol' Timer
Re: When to replace radiator hoses??? (mntn-biker)
Post by Ol' Timer »
Personally, I don't think it makes a difference. When I flushed out the old coolant, I flushed it from the top and then the bottom outlet. I now have just about 100K and I have no intention of replacing any of the hoses. The OE hoses are made/designed much better today. But I do inspect them, generally once (maybe twice) a year.
keithvibe
Post by keithvibe »
top is inlethttp://madstyle1972.com/Repair...1.pdf
Ol' Timer
Re: When to replace radiator hoses??? (keithvibe)
Post by Ol' Timer »
Now we know. I hope by simply flushing this system out every four or five years will keep the heater core happy.
