minet wrote:how did you wire it?
did you have to run a lead to the back from the controller...how tricky was the install?
It wasn't complicated but you have nothing to work with from the factory.
*You need an adequate power supply. I tapped into the fuse box under the hood. Use an auto reset circuit breaker at the power source.
*You need to tap the brake light wire for a signal. Do that just above the brake pedal. You want the wire that is hot only when the pedal is depressed. Use an Ancor type self-stripping quick connector rather than cutting the wire.
*You need a ground connection. Under the dash near the brake controller is easiest.
*You then need to run the brake supply wire from the controller to the trailer connector. You need a heavy gauge (12g minimum) for the wire from controller to connector.
*You should use a seven pin Bargman type trailer connector.
If you read the instructions with the controller it should be relatively easy.
Since you are doing all that I would also suggest running a power/charge line back to the trailer connector. That way you will also be charging the trailer battery while driving. Use 10 gauge wire at a minimum to reduce voltage drop.
I always use an auto reset circuit breaker to protect the controller power supply. The trailer charge line can use a fuse if you wish.
