Crush ring size? (05 base)
Papacat
Post by Papacat »
Quick question re: my 2005 base Vibe.Is the proper crush ring size for the oil pan plug 14mm? I did the oil and honestly don't think I ever saw any crush ring on there, just plug straight to pan. Thinking I should get one.Also, is there a crush ring for the plug on the auto trans. pan? If so, what size? Going to do a drain and fill (yes, T-IV) and want to be prepared.Thanks much, all.
vibedrivermatt
Re: Crush ring size? (Papacat)
Post by vibedrivermatt »
Geeze though I had an answer to this.. but I have no idea
northvibe
Post by northvibe »
vibes have a plain washer or gasket on it. there is 1 yes, did you check the plug to make sure? They can be bought at the toyota dealer very cheap. Any auto part store will sell them as well, plastic ones, but I prefer oem.
oriden
Post by oriden »
i just changed the oil this evening, my washer stuck to the oil pan turns out it wasnt in the greatest shape. i did a quick cleaning and banged it back into shape. the next oil change it will need to be replaced.
