More from SC?
04chargedvibe
More from SC?
Post by 04chargedvibe »
Ok so im not a big guru about what to do and what to change to an engine to give it more punch. But if someone could point me in the direction i can usualy get it done. I was wondering if there are some things i could do/add/improve to help out and give the SC more kick, or the engine in general get more kick. any ideas?
northvibe
Post by northvibe »
you can go to a smaller pulley, get meth to help cool it, tuning solution, ported exhaust manifold, air intake.
scherry2
Re: (northvibe)
Post by scherry2 »
lighter pulleys
keithvibe
Re: (northvibe)
Post by keithvibe »
Quote, originally posted by northvibe »you can go to a smaller pulley, get meth to help cool it, tuning solution, ported exhaust manifold, air intake.^^^this
04chargedvibe
Re: (keithvibe)
Quote, originally posted by northvibe »you can go to a smaller pulley, get meth to help cool it, tuning solution, ported exhaust manifold, air intake.ok so if i were to go through this which pulleys would you guys recommend?
jarmstrong22
Re: More from SC? (04chargedvibe)
Post by jarmstrong22 »
give it a more aggressive tune or change the pulley size, bigger, injectors or a cat back exahaust. If you don't have a CAI that may help as well.
northvibe
Post by northvibe »
crap I havent looked into the kit for so long... I dont want to give you bad numbers but I think its like low 2" range.Also look into the "5th" injector.
keithvibe
Re: (northvibe)
Post by keithvibe »
i'm 90% sure it's a 2.3ditch the fifth injector crap and just get xrs/gt injectors
sikvibe
Post by sikvibe »
Yeah, mine came with the 2.4" pulley, there's a guy @ the matrix site that put on a small aluminum pulley with a diy install..but didn't say where he got it or how much..I looked on vortecs site and there smallest is the 2.4 looks like I'm gunna have to make some calls.Also the fifth injector kinda does suck, It either runs slightly lean or is always just dumping tons of fuel, the slightly lean is porbably because I'm at 5000 feet, but I'm sure the dump is from the fifth. Once I get some mulla saved I'm going to switch to the xrs injectors, but might leave the fifth untill I get an egt gauge.Does anyone now the boost numbers on this stock charger set up?
*03 SIKVIBE*Performance mods in order:18x8 Konig illusion rims w/ falken ziex 235/40R18 tires~1.5" lowered TEIN S. tech springs~GM performance parts supercharger~TRD add-on ECU for S/C~Drop in spectre high flow air filter~Tripod center dash oil pres.,egt/boost, a/f guage pod~Homemade .5" custom S/C thermal intake spacer~1.9" aluminum S/C pulley~150 psi>530cc nozzle water/alcohol injection system~2.5" single cat proflow muffler opposite exit install
sikvibe
Post by sikvibe »
Oh yeah, one more thing..stock my gas mileage was 32..after rims, tires, and charger I'm down to an awful 25..gotta pay to play i guess, eh?
keithvibe
Re: (sikvibe)
Post by keithvibe »
stock psi is 7-8 sometimes will peak as high as 9yea gas mileage will take a huge hit,not to mention your now running prem gas instead of regular.
northvibe
Post by northvibe »
honestly you'd probably see a increase in mileage if you didnt drive "hard" and/or got a aftermarket tune as well. My SS/ms3 got 24 city because I drive hard and 33-35 hwy if I took it easy, but hell with FI how do you?! hahah
DiveNut
Re: (northvibe)
Post by DiveNut »
Quote, originally posted by northvibe »honestly you'd probably see a increase in mileage if you didnt drive "hard" and/or got a aftermarket tune as well. True, I routinely get 29 MPG with my Vibe...95% of my driving is stop and go, rush hour traffic. Average 32-33 MPG on the highway when taking long trips. The key is keeping my foot off the loud peddle. (which is not always easy to do! )
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
