I need to check out the electric schematic for the gear selector shift light.I replaced a oxy sensor and took the shroud off the lower area to get to the plug in the process my light went out and it is d*#n annoying at night trying to get it in drive.Thanks guys,,Mike
It is fairly easy to get the car in drive whether or not there is a light. If you move the shifter out of park, release the lock button, and push the shifter down as far as possible, it will not let you go below drive. It also does not let you accidentally shift into reverse without pushing the button.
