2AZ-FE?
bigdaddyjosh
2AZ-FE?
Post by bigdaddyjosh »
I saw a TRD 2AZ-FE supercharger the other day on a Scion. And, as far as I can tell, that is the same engine in the 2.4 09Vibe. Question is, will it fit?
Pioneer AVH-P8400BH HU Polk Audio DB-6501 Components Pioneer GM-6400F Amplifier K&N drop-in filter Fiberglass Sub box w/10" Cerwin Vega
Re: 2AZ-FE? (bigdaddyjosh)
I'm sure that it can be made to fit... some modifiaction required (as they say)!But can you get the pcm tuned???
bigdaddyjosh
Re: 2AZ-FE? (star_deceiver)
Actually, no, but they can do a pcm swap. Just a diff module is all.
northvibe
Post by northvibe »
swapping a pcm from a scion to a vibe may not work. I dont know myself, has anyone tried it? So with the SC TRD for that engine they just flash the stock ecu right? is the toyota ecu not cracked to be able to be pulled off to a pc and reflashed? or what about emanage or something?
ou.grizzly
Post by ou.grizzly »
That TRD S/C was discontinued due to many issues; not worth it.
northvibe
Post by northvibe »
well..it is a centrifugal supercharger..and belts can slip etc...almost like a belt driven turbo that runs off just like a normal roots blower would work. turbo would be better but a centrifugal like a procharger is just soooo easy to isntall because you dont have to do anything to the exhaust manifold. anywho... lame I really wanted to see a trd SC on a vibe :/
CoryW
Post by CoryW »
http://cgi.ebay.ca/ebaymotors/...19366Trubo kit (havnt looked at it much just found it might work)Price tooks to good to be Legit
