Check engine code p2440
mossaball
Post by mossaball »
I have been having intermitent check engine light problems for about a month or so. So I used a code reader and the cod was P2440. It means that the secondary air injection system switching valve stuck open. Im pretty sure this has to do with my CAI. However I wanted to see if this isnt or is a really problem. Also hope this helps anyone with the same problem that I had.
05' Vibe GTACT ClutchInjen CAI
lovemyraffe
Re: Check engine code p2440 (mossaball)
Post by lovemyraffe »
Double check to make sure you have the code right. I'm not finding that code in my service manual.
here's what I have on P2440
Attached files cip2440.pdf (89.3 KB)
