Require some label help please
vintagegz
Post by vintagegz »
I work at GM Canada and require some information please, looking for a 2005 to 2006 FWD automatic, need the gross vehicle weight information from the label on the inside door jam on the B pillar when you open the drivers door, it has Gross Axle Weight Frt, Rear and Gross Vehicle Weight. The GM data system does not store that info as it is considered outside supplier through joint venture with Toyota. Appreciate any help.
JetBlack09VibeGT
Re: Require some label help please (vintagegz)
Post by JetBlack09VibeGT »
If you are asking what the Curb weight is, I believe its 2701 LBShttp://www.internetautoguide.c....html
I don't have an 05, so I cheated. Ebay to the rescuefrom http://cgi.ebay.com/ebaymotors...3f591
vintagegz
Post by vintagegz »
joatmon thanks, ebay has it all!
