Plastic moulds on the front bottom
ihsn
Post by ihsn »
Hello,One of the plastic shields/moulds that are on the front bottom over the wheel is loose. I saw that it is cracked (screw hole torn) and needs to be replaced pretty soon. My mechanic has fixed it temporarily (for now) by making another hole and attaching it.How much is it? And what is this part called?I was thinking of doing it immediately as I dont want the snow to get in there.Thanks.Not clearly visible here but:
ihsn
Post by ihsn »
Some one, please advise.
Re: (ihsn)
If it just tore out the bolt hole, put a in a washer with the bolt and tighten her up!
liquidsteel
Re: Plastic moulds on the front bottom (ihsn)
Post by liquidsteel »
I didnt replace mine, I just had some old bolts laying around that fit the holes where the PLASTIC bolts were. Im pretty darn sure I sheared the old ones off driving around Omaha. We have alot of snowbanks.Plastic bolts on the bottom of the car holding a plastic shield.... Really?!?!?! What were they thinking?
Water boy
Re: Plastic moulds on the front bottom (liquidsteel)
Post by Water boy »
Quote, originally posted by liquidsteel »I didnt replace mine, I just had some old bolts laying around that fit the holes where the PLASTIC bolts were. Im pretty darn sure I sheared the old ones off driving around Omaha. We have alot of snowbanks.Plastic bolts on the bottom of the car holding a plastic shield.... Really?!?!?! What were they thinking?Bean counters are in control. Not the engineers.
2008
47,891 Added new horns
69,036 Added sound deadening
70,395 Battery
