best buy instal sirius?
oriden
Post by oriden »
so as xmas just past i was lucky enough to recive a sirius car and home pack thing. im just woundering if its a good idea to have best buy go ahead an install it for me or is it an easy install for me? i also have just the orignal head unit in my 05 base vibe. or is this tricking the wife into a new deck? thanks!
Re: best buy instal sirius? (oriden)
Installing it yourself is easy! Here's where I put my sportster 5...The antenna goes well with the other two.But if the best buy install is free then let them do the work!
keithvibe
Post by keithvibe »
Quote, originally posted by oriden » im just woundering if its a good idea to have best buy go ahead an install it for menot unless you really, really hate your car and don't care that they might hack your wireharness to death. Take it to a real stereo shop
oriden
Post by oriden »
thats asome i have the sportster 5 as well. are their any issues with using the stock radio/cd player?
It's easy to install a plug-and-play unit yourself... I can't recommend you letting best buy anywhere near your car. Since you have the stock radio, you'll probably want to get the antenna relay for a cleaner signal. The transmitters in modern Sirius radios are miserable. The adapter has standard Motorola plugs, so you'll have to do a little converting (mini GM female plug to connect to the antenna lead on the car --> male motorola into the relay box and a motorola female --> mini GM male to go back into the factory radio.) That's probably the most tricky part of the install and even with that, it's only a matter of having the right stuff.
oriden
Post by oriden »
asome. tommrow is my weekend so ill give it a shot! thanks guys
dragon64
Re: best buy instal sirius? (star_deceiver)
Post by dragon64 »
Quote, originally posted by star_deceiver »If your A-pillar airbag ever goes off your aftermarket electronics will become flying missles in the passenger compartment. Know of several cases were flying electronic items caused greater injuries than the actual accident would have just by itself.
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
cq358
Re: best buy instal sirius? (dragon64)
Post by cq358 »
if you route your cable around your weather strip then it shouldn't be a problem.Quote, originally posted by star_deceiver »Installing it yourself is easy! Here's where I put my sportster 5...The antenna goes well with the other two.But if the best buy install is free then let them do the work!He is missing a radar then it will become a complete mobile communicating vehicle.
cq358
Re: best buy instal sirius? (ColonelPanic)
Post by cq358 »
are you saying to use the antenna that come with the car?I am wondering is the car has pre-wired atenna?
Re: best buy instal sirius? (cq358)
Quote, originally posted by cq358 »I am wondering is the car has pre-wired atenna?I'm sure it is, xm equipped Vibes have no extra antenna. The wiring for other electronics are already there (fog lights).Quote, originally posted by dragon64 »If your A-pillar airbag ever goes off your aftermarket electronics will become flying missles in the passenger compartment. Know of several cases were flying electronic items caused greater injuries than the actual accident would have just by itself.Well the plan is NOT to get into an accident.... But soon, I'm sure that there will be legislation forbidding the use of any device that interferes with driving... We've already got the cell phone/hand held device ban here, in California you can't have anything suction-cupped to the windshield, all provinces from Saskatchewan east have banned radar detectors. I wonder how long it will take them to ban the manual transmission in order to keep both hands on the wheel...Too many rules.... I dread the day self-drive cars get here, why not just take the bus...But back to the topic at hand.Quote, originally posted by oriden »Awesome. Tommrow is my weekend so I'll give it a shot! Thanks guys! How did the install go?
Sputnik
Post by Sputnik »
I have the sportster 5 as well and its dead easy to do yourself. If I can do it anyone can. I did it in the middle of the freezing cold one day in January a couple of years ago.
GenVibe Global Moderator
keithvibe
Re: best buy instal sirius? (Sputnik)
Post by keithvibe »
Quote, originally posted by Sputnik »I have the sportster 5 as well and its dead easy to do yourself. If I can do it anyone can. I did it in the middle of the freezing cold one day in January a couple of years ago. bet you were running those heated seats though while doing the install.
Sputnik
Re: best buy instal sirius? (keithvibe)
Post by Sputnik »
Quote, originally posted by keithvibe »bet you were running those heated seats though while doing the install. Ha! Could be.
oriden
Post by oriden »
eays install the antenna will need relocation its currently on the front roof arear between the winsheild and the sunroof. siruis radio is the best thing since slice bread and last night i finnaly figured how to change the display colours to red now matching the tac lights.thanks for the tips! pic to follow (im at work)
cptnsolo77
Post by cptnsolo77 »
I helped my brother-in-law install siruis on his Kia Sedona about 3 years ago. It was a pretty simple install. Hardest part was figuring out how to pull the factory radio out LOL.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
