Any photos of 2009 1.8 with 02-07 16" Alloy Rims?
DocDoug
Post by DocDoug »
I am considering a set of 2005 16" alloy rims for my 2009 black 1.8 Vibe. I haven't seen a photo with combination.Thanks
vibolista
Re: Any photos of 2009 1.8 with 02-07 16" Alloy Rims? (DocDoug)
Post by vibolista »
I haven't. Have you found a set of first gen Vibe alloys for your car? Will fit fine... but take a look at TireRack on line to see a choice of 16 inch alloys. Plus you can view their alloys on an 09 Vibe.
DocDoug
Re: Any photos of 2009 1.8 with 02-07 16" Alloy Rims? (vibolista)
Post by DocDoug »
Yes, purchased the 16" 1st gen and they are on their way. If only I can get a straight answer regarding not using the tire pressure monitors and if this affects the ABS and traction control.
ou.grizzly
Post by ou.grizzly »
Quote, originally posted by DocDoug »Yes, purchased the 16" 1st gen and they are on their way. If only I can get a straight answer regarding not using the tire pressure monitors and if this affects the ABS and traction control. You will be fine without the sensors. I am not running the TPMS in one of my Vibe's. Traction Control and ABS will work properly. A light will be displayed on your dash cluster though.
