Condensation in Headlights on 2009 Vibe
ou.grizzly
Post by ou.grizzly »
I have it in both headlights and only when the headlights are ON does this occur, not when sitting overnight while cooling off (which is when this normall happens from my understanding).Weird.
ou.grizzly
Re: Condensation in Headlights on 2009 Vibe (ou.grizzly)
Drivers Side
lowincash
Post by lowincash »
hmm is it humid where you're at? my headlights fogged up like yours a couple months back. i was washing my car in the early morning when it was cool and then when the sun came out and warmed up both headlights had some condensation inside. after half hour or so it went away. but my lights were opened before so i thought that was the case. maybe you can take yours to dealer or add more sealant?
-- 2009 Vibe GT in Jet Black
ou.grizzly
Re: Condensation in Headlights on 2009 Vibe (lowincash)
Quote, originally posted by lowincash »hmm is it humid where you're at? my headlights fogged up like yours a couple months back. i was washing my car in the early morning when it was cool and then when the sun came out and warmed up both headlights had some condensation inside. after half hour or so it went away. but my lights were opened before so i thought that was the case. maybe you can take yours to dealer or add more sealant?It is about 28 degrees right now and this is occurring WHILE the headlights are ON, not when they have been exposed to water or such. I hate to take it in for service, but I have no choice. I will more than likely take it in, print out the pictures to them, let them know what is going on, and hoping they can order new headlights and call me when they come in.
chevelle_lover
Post by chevelle_lover »
What did the dealership that you just took it to do?
If God didn’t want us to eat meat, why did he make the cow so slow? (Ever eaten a cheetah-burger? Nope. And you never will.)
ou.grizzly
Re: (chevelle_lover)
Quote, originally posted by chevelle_lover »What did the dealership that you just took it too do?I took it to the dealer I purchased it from and the service manager said that there is a TSB out that states it is normal, when there is high humidity and or when it is raining out. Per the TSB, it should dry when the lights are onI told him I will be seeking a second opinion. As I told him, it happens when it is in low humidity, not raining, and I get condensation only when the lights are on!Later that hour, I went to another dealer where I go for my $14.00 oil changes. They kept the vehicle and actually looked at it for two days. Did some tests (something about infrared or something). They called GM, tech support, and the regional red I guess; they decided to order two new assemblies. The headlight assemblies should be in sometime next week.
keithvibe
Re: (ou.grizzly)
Post by keithvibe »
noice
I've received that same "normal" response from GM before. Apparently, it was completely normal to have water standing in both headlights and fog lights on that Malibu I once owned. Glad they're doing the right thing and replacing them.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
lowincash
Post by lowincash »
interesting that it's considered normal =/ i highly doubt it's normal. whenever it fogs up it might leave water marks inside the headlight and eventually might become hazy. but glad they're replacing them will you get to keep the old lights?
Vibe_dude
Post by Vibe_dude »
You should NEVER have water or moisture inside your headlights.It has a small crack or air leak somewhere..good to see that they are changing them for you.
keithvibe
Re: (Vibe_dude)
Post by keithvibe »
Quote, originally posted by Vibe_dude »You should NEVER have water or moisture inside your headlights.It has a small crack or air leak somewhere..good to see that they are changing them for you.agreed, I had a headlight that fogged on me once and even with HIDs in them it reduced the light output from that light by almost half. It was like driving in fog. The lights did unfog but took quite awhile and as soon as the car was shut off again it fogged again.
JoeDibajio
Post by JoeDibajio »
Man, you are lucky if that is all you have, My dealer wont even change mine, they said 'Half Price' which comes to $275 each on my '07 Vibe.
