Need Help! Can a connector be found and where???
ou.grizzly
Post by ou.grizzly »
This is a door panel switch and wondering if there is a place that sells the connectors to create your own wiring harness?
Re: Need Help! Can a connector be found and where??? (ou.grizzly)
Check out a salvage yard and see if you can grab one off of another Vibe/Matrix/Corolla. Is the connector from the first gen the same as the second gen???
Sublimewind
Post by Sublimewind »
Yeah, you won't find it other than a salvage yard, they are custom built for them...
