shouldn't be too hard. open the glove box. and then pinch the two sides together. when you do, the 2 'stops' will clear the walls of the dash and the box should swing all the way down... while you're at it, you can also replace your in-cabin air filter
de-badged o4 vibe
o2 triumph speed four
