Performed TB coolant bypass...
DrunkenMonster
Post by DrunkenMonster »
Disconnected both hoses. Went to auto parts store and bought a coolant connector. Clamped both coolant hoses together. Very easy modification, Noticed slight improvement.
2005 Vibe Base with M&TKenwood KDC-MP342UAvital 4103 Alarm/Remote StartK&N Panel Air Filter, Removed Silencer, TB Coolant Bypass1998 Jeep Cherokee UKFlowmaster Super 44Cobra 25 LTD CB 2 JL Audio 10W0's / TMA 500
djb383
Re: Performed TB coolant bypass... (DrunkenDixie)
Post by djb383 »
You may want to reconsider the bypass, especially with winter coming on. It's been posted on the Internet that coolant is plumbed around the TB to heat the incoming air. That is NOT the engineering design and is a myth. The purpose is to prevent ice from forming on the backside of the TB butterfly, which can interrupt air flow when open and cause the butterfly to stick partially open at idle. Under certain conditions, ice can form in the TB even during summer months. Again, the coolant does not heat the intake air as the air passes through the TB much too quickly to become heated.
DrunkenMonster
So then why does this particular engine have it and other engines don't use it say for instance the Ecotec?
djb383
Re: (DrunkenDixie)
Post by djb383 »
Can't answer that but other engines do use it. Our Saturn Vue V6 (Honda VTEC) has it as well as GM LS engines. Our 5.7L Tundra had it, IIRC. Even our old '92 5.7L Chevy P/U had it.
djkeev
Post by djkeev »
Do some research on Carburetor Icing. The airplane forums have a lot of information for this is a very serious issue when 1000's of feet in the air! On land, the car runs poor or stalls, big deal! No offense intended but people a lot smarter than you (I assume, don't know you) and for sure smarter than I have spent a lot of money not only to design but to construct and install this in your car. Believe me, it wasn't done just to irritate people! Some design work is to shut the Feds up with emission regulations though. There hasn't been much worse than the old air pumps during the 60's and 70's to screw up a car.Think twice about this mod.Dave
(o ! /o) (o)=I=(o)
TONY TAT2
Post by TONY TAT2 »
Had a 65 mustang with it,only on the 6cyl's tho. I by pased the1on my 85 vette.
Sublimewind
Post by Sublimewind »
My subie uses a coolant charged TB... it's silly for high performance guys to run it, but on a Vibe, the difference is negligible.. Especially on my car as it's not DD'ed.. I've bypassed it, but I won't be driving in the winter either.. On my car I didn't even need any fittings, I just removed one hose, shortened the other and popped it on the other fitting with the factory clamp... 5min max, zero cash... lol..
I know of at least one person here who installed a CAI, then got surprised by water, hydrolocked, and subjected the car to Sudden Engine Death Syndrome. In spite of that, CAIs still seem to be a very common performance mod. An objective observer might think that deliberately putting such a SEDS likely device on a car is lunacy, but it's popular. By comparison, the risk of a little incovenient intake icing seems trivial.
L5K
Post by L5K »
Problem solved. Just install a dehumidifier under the hood.
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
djb383
Re: (joatmon)
Post by djb383 »
If a rough idle and/or poor engine operation/performance could be attributed to TB icing, it might not be considered trivial.
VforVIBE
Re: (joatmon)
Post by VforVIBE »
Quote, originally posted by joatmon »I know of at least one person here who installed a CAI, then got surprised by water, hydrolocked, and subjected the car to Sudden Engine Death Syndrome. Didn't he do that like 2-3 times? Quote, originally posted by DrunkenDixie »Disconnected both hoses. Went to auto parts store and bought a coolant connector. Clamped both coolant hoses together.I hope not in that order I did the TB bypass... no ice yet.
djb383
Re: (VforVIBE)
Post by djb383 »
How do you know? Have you looked on the backside of the butterfly that's inside the TB while the engine is running?
VforVIBE
Re: (djb383)
Post by VforVIBE »
Quote, originally posted by djb383 »How do you know? Have you looked on the backside of the butterfly that's inside the TB while the engine is running? It's Florida, we have a law about ice being anywhere other then in our drinks, it's just not allowed.
DrunkenMonster
Re: (VforVIBE)
I drove my truck sorry for any confusion...
vintagegz
Post by vintagegz »
The worst thing is on a humid/damp day on the highway your throttle can ice up, any season, and when you lift off the accelerator pedal the car keeps going, very dangerous. I can see the mod if you are racing and want a miniscule edge, but poor choice on the street.
djb383
Re: (vintagegz)
Post by djb383 »
+1........Use your thumbnail to let air out of an inflated tire and feel how quickly your thumb will get cold, even when it's hot outside. Same principle is at work.....air moving rapidly from higher pressure (front side of TB butterfly) to lower pressure (back side of TB butterfly). Again, the circulating coolant warms the metal in the TB (not the incoming air) to prevent ice from forming on/sticking to the back side of the TB butterfly.
djkeev
Re: (VforVIBE)
Post by djkeev »
Quote, originally posted by VforVIBE »It's Florida, we have a law about ice being anywhere other then in our drinks, it's just not allowed. Ummmm, I recall being in Florida, Palm Beach area, a few times waking up to an ice covered world!! Must only be illegal on the West Coast??Dave
(o ! /o) (o)=I=(o)
djb383
Re: (djkeev)
Post by djb383 »
Yep, and IIRC, the NASA dudes (in Florida) take ice and icing conditions seriously.
Sublimewind
I'll risk the ice, thanks... lol..
djb383
Re: (Sublimewind)
Post by djb383 »
What is that.....a Transformer? LOL
Sublimewind
Re: (djb383)
Quote, originally posted by djb383 »What is that.....a Transformer? LOL Pretty much... lol..
Water boy
Post by Water boy »
The only items I can recognize are:RadiatorWindscreen washer fluid tankAlternator
2008
47,891 Added new horns
69,036 Added sound deadening
70,395 Battery
Re: (Water boy)
Quote, originally posted by Water boy »The only items I can recognize are:RadiatorWindscreen washer fluid tankAlternatorWhat??? You didn't study? There's going to be a quiz on it later!
keithvibe
Re: (djb383)
Post by keithvibe »
Quote, originally posted by djb383 »What is that.....a Transformer? LOL Quote, originally posted by Sublimewind »Pretty much... lol.. in to a pile of goo
djb383
Re: (keithvibe)
Post by djb383 »
With all that tubing/piping maybe it transforms into a 5 piece brass band, or something.........playing music to Sublimewind's ears when he mashes the go pedal. Man that puppy blows.....get it. ROTFLMAO
