Brake squeaking when in park???
cptnsolo77
Post by cptnsolo77 »
Was sitting in a parking spot ( car off & parked ) I noticed when I pressed the brakes would hear a squeak. Also when i pulled on the parking brake I got the same sound. Does my parking brake need to be lubed?
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
lovemyraffe
Re: Brake squeaking when in park??? (cptnsolo77)
Post by lovemyraffe »
You need to take the mouse out of your brakes. This was the cause of a squeaky brake syndrome of mine a few years back. GRAPHIC CONTENT CONTINUES BELOW...A mouse had somehow got its head stuck between the brake pad and the rotor. Needless to say, the mouse was dead and didn't have a head ("No more rhyming and I mean it!"). Once I removed the mouse, no more squeaking.
Whelan
Re: Brake squeaking when in park??? (lovemyraffe)
Post by Whelan »
I know that there is a noise when pressing the brake pedal in Park and releasing. But to me it sounds normal like the vacuum pump or pressure from the caliper pistons.
2012 GLI Autobahn 6MT
Sublimewind
Post by Sublimewind »
It's just the rear brake shows sliding on the backing plate.. shouldn't need to worry, but if you are, do a brake jerb..
Whelan
Re: (Sublimewind)
Post by Whelan »
Dey Tuuk ur Jubbs!
Sublimewind
Re: (Whelan)
Quote, originally posted by Whelan »Dey Tuuk ur Jubbs!You caught it...cool
crug75hid
Post by crug75hid »
i think whatever the reason may be, you need to get your brakes fluids check. and lubrication of the hardware is a later purpose. be safe
