Am wondering if the two roof cross rails on the Matrix roof rack are moveable (they move forward or backward) or are they stationary??? Would appreciate any feedback.Thanks,Bob
2009 Pontiac Vibe Red Hot Metallic, 2.4L w/5 speed auto., Sun & Sound Pkg., Preferred Pkg., A/C.2009 GMC Acadia SLT-2 AWD"If a man does his best, what else is there?"-- General George S. Patton Jr.
I'm sure there is a '09-'10 Vibe owner w/ a Matrix roof rack out there that can answer my question.....Am thinking about buying the Matrix rack and am curious about the cross rails..Thanks.
Based on this picture, I would say the cross rails may be stationary. I think your best bet would to send a PM to one of the members in this thread here who has the rack, they would be able to answer your question http://forums.genvibe.com/zerothread?id=38222
Ya--I think you're right. The rails do kinda look stationary. Will PM & question a member who has the Matrix rack. Thanks for your input,Bob
Tonebalone---Thank you....The photo looks like a long bolt may run thru each of the 4 roof rail corner pieces, thru the long black plastic support rail and then screws into the metal roof somehow. Is that correct???Bob
There are four captured bolts and clamps on the cross rails. The side rails have a 'cut out' where the clamps 'catch'. You attach/remove the cross rails with an allen wrench. The side rails attach with four bolts each (8 total) to existing threaded bolts in the roof structure under the plastic covers.
Quote, originally posted by toycar »There are four captured bolts and clamps on the cross rails. The side rails have a 'cut out' where the clamps 'catch'. You attach/remove the cross rails with an allen wrench. The side rails attach with four bolts each (8 total) to existing threaded bolts in the roof structure under the plastic covers.toycar,That is EXACTLY the info I'm looking for. Thank you very much.... Bob
