Anybody use a a trailer hitch/cargo basket combo on their Vibe?
Cougar Vibe
Post by Cougar Vibe »
When we travel we use a Yakima cargo box, but I'd like to add a trailer hitch to my Vibe so I can put a rear-mount basket on it. The problem is that I've yet to see a Vibe (or any other small car) running around with one on there. I'm sort of afraid that four suitcases stuffed with crap will really weigh-down the rear suspension (even though I have an AWD w/independent rear). Anybody use a cargo basket and can recommend a brand? Thanks in advance!
Re: Anybody use a a trailer hitch/cargo basket combo on their Vibe? (Cougar Vibe)
seems like Vibe trailer hitches are rated at 200 - 250 pounds tongue weight, and with a hitch cargo box, it's all tongue weight, so you should be ok as long as the box and everything you put in it is under 200 pounds.
v329799
Post by v329799 »
I have a 09 AWD with trailer hitch . I use a carrier and I have put 5--5gal cans of diesel on the back. Next time I will only put 4 cans just a few lbs to many.I have a 2" rec for the carrier so I have to use a reducer down to the size on the Vibe. The back of carrier drags just a few times with the extra can going on certain turns and inclines.I now have an adapter to raise the carrier another 2" but it will set my carrier back another 3 or 4 " further It may help and it may not haven't had time to see if it was wasted money.Getting back to your question I would think you should be fine with 3 or 4 suitcases and keep weight down to around a 100-125 #
