Okay I found a topic on replacing the rear wiper. It said to twist the blade assembly counter clockwise and the blade would come off the arm. I twisted but it would not pop loose. Saw lots of post about refills but to late I already bought the blade assembly.I am afraid to twist harder because it looked like I might damage the are.Help fellow Vibers. It is an 07. Info on replacing the front ones would also be appreciated.
I'm not 100% sure on the rear wiper. I've only changed mine once. The front wipers are simple. There is a little tab on the underside of the wiper arm that you push and then slide the wiper blade down the wiper arm. To install, is just opposite of that.
