Griots Garage sells clear film that can be cut to fit any place on your car. It advertised to protect the leading hood edge from stone ships and rocker panels from kick marks. It comes by the foot in 3/8", 2" and 4" wide strips:PAINT SAVING, CLEAR PROTECTIVE SHIELDThis clear, protective shield works excellent at protecting painted areas more prone to chips and scratches. (I cringe every time I hear a high-heel shoe hit a painted door sill.) Simply cut the desired size shield, apply positioning spray to the surface, move the cut shield into place, then squeegee out the Positioning Spray and you're done! An instant clear shield that protects your paint! Use it on front ends, along door edges, around tire wells, inside door jambs, along door sills, painted bumpers - I've had this protective shield on my wife's Suburban's door jambs for two years now, and I could peel it off at any time and the paint would still look brand new. Available in three widths. 12 mils thick. Sold by the foot. Not for use on plastic bumpers and repainted vehicles.
http://www.griotsgarage.com/catalog.jsp ... &SKU=77890
