There is a weird sound that happens about 80% of the time. Here's what to do to recreate the issue1. Turn the car on2. Reverse out of your parking spot, turning the wheel to position yourself towards exit3. Press the brake to slow down your idle reverse while still turning the wheel before you shift into Drive4. Hear "click-click, sometimes "clink-chunk", sometimes "chu-chunk"Most of the time this happens in reverse, but sometimes happens while I pull forwards out of a parking spot too. I only hear it when pulling out of parking sports, so it only happens in the first turn the car makes after being off for some period of time.Has anyone else heard this?
08 Base Platinum/Grey.Injen CAI. 10" sub & amp. Ground wire kit. Scangauge II. Honk on lock kit. Siren & PA. Fog light protectors. Insulated AC line. Double-height console lid. 12v outlet in console.
and that would be what? more importantly, if i take the car into a GM dealership for warranty service, will they know what i'm talking about and fix it for free?
I don't think CV, I think it's the same clunk most of us have when driving in reverse then going fwd:http://forums.genvibe.com/zero...61357I've pretty much figured it's just a normal sound it does....
Quote, originally posted by Kamikaze »I don't think CV, I think it's the same clunk most of us have when driving in reverse then going fwd:http://forums.genvibe.com/zero...61357I've pretty much figured it's just a normal sound it does....A single click or clunk maybe, but if it's a series of clicks when turning the wheel hard, or changing direction, it sounds like a CV joint... Headcold, the CV joints are part of the drive axles that run from the transmission to the front wheels...
