Cargo Cover for 2010 Vibe
Vulcan05
Post by Vulcan05 »
This is my first post to the GenVibe Forums. I bought a 2010 Vibe three weeks ago, and the lack of a cargo cover was a surprise. Following the lead of a couple of other members, I made my own. The 2010 (and probably other years) have mounts around the top of the cargo area for the folding factory cargo cover. I removed these and put two adjustable shower curtain rods ($5.99 each at Menards) across the area, using the holes left. I made a two piece cover from eighth inch pegboard and covered it with carpet remnant. I got enough carpet to also cover the cargo floor and seat backs. Total cost was $12 for the rods, $5 for the pegboard and $10 for the carpet. I made the pattern for the cover halves with cardboard and transferred that to the pegboard, cut it out with a jig saw and glued the carpet to them with Elmers white glue. The floor and seat back carpet is held in place with Velcro strips for easy removal if required. The covers and shower curtain rods can all be removed in about 30 seconds. Start to finish took about 3 hours.
2010 Vibe. Moon roof, Monsoon, 2.4 engine, 5 speed auto, cruise, dark gray.
beemerphile1
Re: Cargo Cover for 2010 Vibe (Vulcan05)
Post by beemerphile1 »
Pictures, we need pictures! Welcome to the forum.
Vulcan05
Re: Cargo Cover for 2010 Vibe (beemerphile1)
Post by Vulcan05 »
Click the link for pictures. I still have to remove the carpet on the covers and glue and staple them down. When the Picassa page comes up, double click on the first small picture and then just click the blue left-right arrows above the picture. Let me know if you have any problems.http://picasaweb.google.com/nh...eTnGg
Wolfman213
Post by Wolfman213 »
Looks good! Not a fan of the green though. Anyone know when they went from metal to plastic? Gen change I assume?
lowincash
Post by lowincash »
nice job. good idea with the curtain rods but i too am not a fan of the green lol was there any other colors or you wanted green? i would have went with black =P
-- 2009 Vibe GT in Jet Black
Vulcan05
Post by Vulcan05 »
It was either green or a bright maroon-red. The only gray remnant looked more like plastic grass than carpet. Green was the lesser of three evils.
beemerphile1
Re: (Vulcan05)
I love your use of the handyman's secret weapon! You must be a member of Possum Lodge.
Vulcan05
Re: (beemerphile1)
Post by Vulcan05 »
I'm Old Man Sedgewick's nephew. "I'm a Man, but I can change, if I want to, I guess."
BadBrew
Post by BadBrew »
I used heavy duty entry carpet with rubber backing bought at walmart, I had to buy 2 to cover everything. I'm carrying lots of boxed heavy stuff (computers, servers...) so at first I used velcro like you did but then I glued everything to make it permanent because the velcro just wouldn't stand.Here's a pic to give you an idea on my '05...
2005 Lava Vibe base Garage
Whelan
Re: Cargo Cover for 2010 Vibe (BadBrew)
Post by Whelan »
You should have cut out where the slide tracks are so you could still use the anchor tie downs. Unless they got rid of those on the 09+I used electircal conduit for my supports in the cargo cover. The thing holds 50 lbs.
2012 GLI Autobahn 6MT
lovemyraffe
Post by lovemyraffe »
Welcome! The idea and finished product of your cargo cover is great, but I do agree with everyone else (the green is kinda weird).
Good use of pegboard..... green, everyone else has already said it..... I'm pullin' for you, we're all in this together!Quando Omni Flunkus Moritati
Vulcan05
Re: (star_deceiver)
Post by Vulcan05 »
OK, guys, the green is gone. Well, at least it's covered up. I found a gray 3x5 rug on sale. I just laid the two peg board pieces (with the green left on them) over the rug and cut out a new cover. You're right. I had become used to the green (or I just learned to ignore it) but the gray is an great improvement. Still have less than $30 invested.
epcIII
Post by epcIII »
You have a grease pit in your garage? Lucky! There's a guy in our neighborhood with a car lift in his garage where he stores his 'baby' and he parks another car under it. I've always wanted to stop and ask him how he closes his garage door with the car jacked up there.... Anyways, I think it would be cool to have a grease pit in my garage.
Vulcan05
Post by Vulcan05 »
Click on this link to see pics of my grease pit.http://picasaweb.google.com/nh...bulgE
epcIII
Re: (Vulcan05)
Post by epcIII »
Very sweet Vulcan! Definitely something I would want to have in a garage! Do you change your own oil there? If so, do you prop the used oil pan up close to the car so it doesn't splash?
Vulcan05
Re: (epcIII)
Post by Vulcan05 »
Quote, originally posted by epcIII »Very sweet Vulcan! Definitely something I would want to have in a garage! Do you change your own oil there? If so, do you prop the used oil pan up close to the car so it doesn't splash?This is embarrassing, but here is the truth. The first time I changed oil in the pit, I put a piece of hose on a funnel and put the other end in my oil drain pan. I managed to get oil on my shirt, pants and shoes. A real mess. I was telling my brother that I guess I'll have to buy one of those adjustable drain pans like service stations have (or used to). He just looked at me and said, "Why don't you just put one of the boards back in right under the drain hole, set your drain pan on it, and let it drain in that?" DUH!!!!! Sometimes the solution is so simple that we can't see it.
epcIII
Re: (Vulcan05)
Post by epcIII »
That's funny--sounds like something I would do!
Prime Si
Post by Prime Si »
Good Job on this....i've been thinking of doing something similar, i can't believe the dealership wants $90 for the flimsy piece of fabric they're calling a cargo cover. Just one question for you....is there anything keeping the pegboard in place or does it just rest on the rods?
Vulcan05
Re: Cargo Cover for 2010 Vibe (Prime Si)
Post by Vulcan05 »
Quote, originally posted by Prime Si »Good Job on this....i've been thinking of doing something similar, i can't believe the dealership wants $90 for the flimsy piece of fabric they're calling a cargo cover. Just one question for you....is there anything keeping the pegboard in place or does it just rest on the rods?The peg boards just lay on the shower rods. They don't move around and they don't rattle, probably because they have carpeting on both sides and they are up against the back window and the back of the seat. As stated, since I took the pictures, I have found a piece of gray carpet which I just toss over the original green.
