Quote, originally posted by jscherf92 »Sublimewind: I was planning on two constant circuits with some of the lights and an additional circuit run from a streetglow sound module switch. Why disconnect the stock sub? Just wondering. It wouldnt add power to the door speakers or anything would it? Disconnect the stock sub, because it likely sounds worse than the 2-10's.. it also drains power from the car doing so... no need for it.. You could run a heavy constant circuit to a central location and then run mutiple switched circuits off from it too, if you liked.. so say you wanted just the lights under the seats on, you could do that.. You could even have them set up so that they came on with the doors opening, and you could switch them on at any time... It really depends on how far you want to go... I just bought a bunch of round rocker switches for my Subie, I'm going to put in a bank of 6 I think... not all will be used right now, but when it's time, I'm already ready already... lol... I also have one of these nifty fuse blocks from Blue Sea Systems
http://bluesea.com/category/5/21/productline/126It's going to be the "hub" of my car... I'm actually going to run all of my audio/video from it, including my amps (which are fused at a mere 20a on the largest amp)
