Storing tires/wheels
MonotoneSatellite
Post by MonotoneSatellite »
Greetings all,I have a question regarding storage of tires not in use. Are there any special precautions you should take to ensure your all seasons last the summer? Or to ensure that your summer tires last the winter? I have never had a set of summer tires before and would appreciate any advice you can give.
meathead333
Re: Storing tires/wheels (Salsa!)
Post by meathead333 »
quote:If you store the tires on the rims, Reduce the air pressure by half and Keep them in an upright positionwhat does this do?
My myspace.com profile My 73' Bronco Cardomain page
quote:If you store a tire (on the rim) flat on the ground and pile them up, it can give a bend to the sidewall.....The weight of the rim will move the rim downward and produce a pressure on the tire that could deform it. Most tire experts recommend storing tires vertically on their treads to minimize stress and possible tire distortionActually, I read somewhere it's recommended storing them vertically regardless of whether they're rim-mounted or not.
meathead333
ok i see, what about lowering the air pressure? whats the purpose of that?
MonotoneSatellite
Thanks for the Info. I'll be sure to do that when I get some new wheels/tires.
