Hello,I went to canadian tire yesterday to locate iridium plugs yesterday, they said there are none for the 2007.I went to NGK spark plugs canada to locate the plug number and they list no plugs for the 2007.Ngksparkplugs.com list ifr5a11. Has anyone used these in their 2007 base model?Just wondering if it is the same one, am curious why ngk canada does not list them. One would think they are the same engine as the u.s. models.thanks
Thanks for the suggestion, but I cannot find Denso's in canada. The options so far are:Dealer-ac delcoLordco/Canadian tire-ngk platinum or bosch irridium
There shouldn't be any difference between 2003-2008 as they all use the same engine
Quote, originally posted by billme »Thanks for the suggestion, but I cannot find Denso's in canada. The options so far are:Dealer-ac delcoLordco/Canadian tire-ngk platinum or bosch irridiumDid you check at the parts counter at Canadian Tire, NGK iridiums are only available behind counter. Got mine 1 month ago, I had to ask to get them...(05 Vibe base, same engine as yours)
