Wet passenger floor?
x97labelle
Post by x97labelle »
OK, anyone know what it could be if the carpet on the passenger floor is wet? I haven't pulled the carpet back to see what it is yet. I think it is most likely to do with the A/C.
bull77
Post by bull77 »
welcome to genvibe! you're right -- common issuehttp://forums.genvibe.com/zerothread?id=10509http://forums.genvibe.com/zerothread?id=22981http://forums.genvibe.com/zerothread?id=10977http://forums.genvibe.com/zerothread?id=10203
x97labelle
Re: (bull77)
After reading those, that has to be it. I will climb under there tonight.
x97labelle
Re: (x97labelle)
Well, I guess I have to look for the sunroof drain hose now. I pulled back the carpet near the console and found what has to be the A/C drain hose. Maybe 1/2" line with a zip tie. Securely fastened.I will look for this sunroof drain hose now, and probably run the A/C this weekend just to make sure that other hose is not clogged or something.
ou.grizzly
Post by ou.grizzly »
Any updates?
