I'm just curious. I'm looking at my options for an MP3 CD player in my Vibe and if I can go stock that is preferable. I don't need anything fancy and factory CD players more seldom "go missing" than aftermarket ones.
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
Not sure about the connections, but the biggest problem is that the radio will not physically fit. The 2009 is shaped entirely different, it has that 'H' shaped opening in the dash. There were available versions of the CD player that played MP3's toward the last couple of years on the first gen so if you can find one of those it would be a direct connect and a perfect fit. But those were few and far between, it seems.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
No and No... Go aftermarket, you can then pick and choose any feature or price you like... Install is easy... I have a tutorial about it... makes it even easier..
