Engine Management 2ZZ
Herb
Post by Herb »
Has anyone looked into engine management for the 2ZZ?Folks on the NewCelica forums talk about the Apexi Power FC, http://www.apexi-usa.com/products/?id=5354 but I'm not sure I have read any Vibe GT/Matrix XRS users using it.Are there other options available? I'm not too crazy that this doesn't support OBDII which probably would make my ScanGuage useless
wyatt89
Post by wyatt89 »
I don't believe there are a whole lot of options for the matrix/vibe 2zz unless you go with something universal like a hydra or megasquirt. There are also certain injector controllers that will probably work too but any of these will need to be tuned by a professional.
'04 lava GTSRI, Progress rear sway bar, Infinity reference backs, components in the front, Infinity Kappa 124.7w sub, Alphasonik 600rms@2ohms for the sub, alpine head unit, worst paint ever!
northvibe
Post by northvibe »
depends if you just want a piggy back or a full em replacement. The full replacement is expensive. but if you just want a tune why not look into a piggy back.....
Herb
Re: (northvibe)
Post by Herb »
Quote, originally posted by northvibe »depends if you just want a piggy back or a full em replacement. The full replacement is expensive. but if you just want a tune why not look into a piggy back.....I already have a Unichip. However I am looking into what I need for the DD Performance Intake Manifold. Many are upgrading the fuel injectors as well and are adjusting the lift engagement and I'm not sure the Unichip can do that.
northvibe
Post by northvibe »
couldnt you get a lift controller seperate? Then with bigger injectors and a IM just have it tuned at a unichip cert shop?
