Catalytic Converter Lifespan and Diagnosis
Mojo72
Post by Mojo72 »
I'm at 82K+ miles and am wondering when/if I need to start considering a catalytic converter replacement. What are some telltale signs?
2004 1.8L (1ZZ-FE) Vibe (Lava Red)16" Michelin Destiny tires
Re: Catalytic Converter Lifespan and Diagnosis (Mojo72)
Geez, I'm at 115,000 and I haven't given it a thought. I don't replace anything until it breaks. Tell tale signs of a clogged Cat: your car doesn't start. My advice: carry a cell phone, check your tires weekly for spikes and nails, and ENJOY YOUR RIDE; it's a Corolla!!
zionzr2
Post by zionzr2 »
Quote, originally posted by Mojo72 »I'm at 82K+ miles and am wondering when/if I need to start considering a catalytic converter replacement. What are some telltale signs?drop in fuel economy. foul odor (i.e. rotten eggs) Drop in performance. are signs to be aware of.
Re: Catalytic Converter Lifespan and Diagnosis (zionzr2)
What zionzr2 said plus check engine lights w/P0420's and such.None of those symptoms? Save your pennies and wait until they show up.
Mojo72
Re: Catalytic Converter Lifespan and Diagnosis (ColonelPanic)
Post by Mojo72 »
Sounds like I'm good to go. Thanks for ALL of the great feedback!
alexod
Post by alexod »
118,010 miles, the Check engine light came on. Stopped by the repair shop, grinned grimaced and they read the code for me.Getting a new Cat next week(2004 auto, FWD, mostly freeway commute driving)
'04 Vibe, 1 careful owner, 120,000 miles.
Mojo72
Re: Catalytic Converter Lifespan and Diagnosis (alexod)
Post by Mojo72 »
That sucks. How much are they charging you?
borquezmike
Post by borquezmike »
Got the rotten egg smell at 101,000. I went ahead and replaced the whole downpipe assembly myslef for 500.00, including oxygenh sensors. Funny though Pontiac wanted 500.00 and Toyota wanted 1000.00, go figure. Stick with good gas this problem is less likely to come up.
msu90
Re: Catalytic Converter Lifespan and Diagnosis (borquezmike)
Post by msu90 »
Nice! Wish I had the know-how around my car to do it. How long and how difficult is it to do?
Mojo72
Post by Mojo72 »
How often did you change your O2 sensor(s) before the catalytic converter went south? I've read where worn out O2 sensors can shorten the lifespan of catalytic converters.
06pvibe
Post by 06pvibe »
Next time, try this site: http://www.discountconverter.c...s.cfm$245.03 and the shipping is good. Used these guys when my wife's Saturn gave it up @ 135k ($168 for the Saturn.) Or simply buy a universal and have it installed by your favorite muffler shop... but don't forget a new 02 sensor along with it.
hskater26
Post by hskater26 »
im going on my second cat within 40k miles.
-2003 Base Vibe-2002 Ducati ST2
borquezmike
Re: (06pvibe)
In California you are required on 2002+ newer vehicles to have OEM conveters installed, no universal units are allowed. Now this may not be a issue if the smog guy doesn't look, but due to its design and location I would not suggest using an aftermaket converter. You should replace your O2 @ 100k, earlier if you drive your car hard.
Mojo72
Re: (borquezmike)
Post by Mojo72 »
My upstream O2 sensor coded P0133 about 5 times last winter at around 80K miles so I replaced it in May09 with a Bosch exact fit sensor that's seems to be getting the job done. Unless it starts coding, I'll wait until 100K before replacing the downstream sensor.
