Clutch feels better *before* the engine gets too warm
21Rouge
Post by 21Rouge »
I have an 05 5 speed with about 50k miles. I notice that the clutch engages and disengages much more smoothly for the first while after startup. That is later on in the drive, I must be more careful when releasing the clutch going from 1st to 2nd. Does that make sense?Is it possible that this could be the consequence of having too much fluid in the hydraulic clutch/brake master cylinder reservoir? Should it be at the min mark when the car is completely cold...say after sitting all night?
Re: Clutch feels better *before* the engine gets too warm (21Rouge)
I haven't checked for a long time, but I think the level tends to stay about the same hot or cold. I know on mine it's easier to stall after it's warmed up, because I don't get the assistance of the cold idle boost.
northvibe
Post by northvibe »
have you changed your transmission oil?
