taillight fuse keeps blowing! need help?
vibe11
Post by vibe11 »
the brake lights will work but the fuse to my taillights keeps blowing any sugggestions
Paragon
Post by Paragon »
Make sure you are using the proper size fuze.If it keeps blowing, there is a short somewhere or something is causing it to draw too much current.Did you change the bulbs or something?
audiovibe
Post by audiovibe »
Does the fuse blow the minute the car is turned on or at night when the lights turn on? Where is your remote wire and power wire ran?
ewakko
Re: (audiovibe)
Post by ewakko »
I'm having this same problem. I replaced the fuse, pulled into the garage to check it and it was fine. The next time I went out at night, it was blown again.
Sublimewind
Post by Sublimewind »
a short somewhere.. have either of the cars been modded in any way? panels removed/replaced for say an audio system?I would say a pinched wire..
