Fog lights come on even when they're not turned on
Olegario
Post by Olegario »
This started happening recently. My fog lights (or auxiliary lights, or whatever they're called) come on whenever the night headlights are on, whether by light sensor or by turning the light knob one click. It used to be I had to turn the light knob one more click for those lights to come on. Any ideas what I should look at or look for?2003 plain vanilla Vibe + after-market cruise control
Wolfman213
Post by Wolfman213 »
Did you notice it start happening after you installed the cruise control or did it exist prior?
djkeev
Post by djkeev »
Hi, not sure of your year but my fog lights have a separate switch on the head light stalk about mid way down (2007) Wait, go here.......http://www.genvibe.com/images/...e.pdfOwners manualhttp://www.genvibe.com/images/...e.pdfPage for head light stalk, see the little rubber dimpled part between the off's. Rotate it.(sorry if you know this and I just insulted you)Dave
(o ! /o) (o)=I=(o)
ClunkClunk
Post by ClunkClunk »
Totally unrelated, but it's nice to see someone from SB on here :-) I lived there for two years while my girlfriend got her undergrad from UCSB. I miss it dearly at times, particularly La Super Rica (Mexican restaurant).
2008 Frosty two tone (and 3 other Vibes)
Olegario
Re: (Wolfman213)
Post by Olegario »
This started happening long after the cruise control was installed.
Olegario
Tail between legs
Post by Olegario »
Operator error. Took a better look at the multifunction lever. I'm deleting my login and will re-register under a different name in a different city. Thanks for the help.
keithvibe
Re: Fog lights come on even when they're not turned on (Olegario)
Post by keithvibe »
djkeev
Re: Tail between legs (Olegario)
Post by djkeev »
Much respect to you, it take real man to say "ooops"!Dave
(o ! /o) (o)=I=(o)
