Hi guys..got a 2003 GT...yellow check en gine light went on last year..they changed thermostat...worked fine until it went on again about a month ago..got it into the shop..has a P0172 code....rich gas mixture...the cleaned my injectors and flushed out my radiator..2 days later..yellow light is back on...has any of you ever gotten this??
MAFMass Air Fuel sensor. It's located in the tube of your air intake little black thing that is held in by two screws. Disconnect your battery, remove the sensor, clean with MAF cleaner, Put sensor back in intake. Reconnect your battery.
did it this afternoon...what a easy fix...got some hp back...now I'll wait a few days to see if it really was that...I'll keep you guys posted.Thanks again
