Headliner Water Leak
yoshi64
Post by yoshi64 »
Attached is a picture of what im talking about. Took it to the dealer couldn't find the problem. happens in all four corners depends on where car is during rain (e.g. on a hill, flat....) figured it had something to do with moon roof but i don't know. any ideas would help me out.here is imageshack, so i don't have to wait for approval.
ou.grizzly
Post by ou.grizzly »
What year Vibe?
yoshi64
Re:
Post by yoshi64 »
04 Base
ou.grizzly
Crap, it is not under warranty. Have you thought about taking it to a different shop besides the dealer? The drains on the moon roof have to be disconnected or clogged for sure.
yoshi64
Re: (ou.grizzly)
Post by yoshi64 »
yeah it sucks, its got 97k miles on it. I'm not sure who would look into that type of thing.. most places i would think wouldn't touch it.
Raven
Re: (yoshi64)
Post by Raven »
My first guess would be the antenna hole after the moon roof. There's a "How to" on removing the headliner somewhere on this site.
btimlake
Re: Headliner Water Leak (yoshi64)
Post by btimlake »
I had a leak coming through at the joint of my A-pillar cover and headliner. I suspected the moon roof drain. I got the whole headliner down, then went to test the tube to see where it was leaking. That's when I saw a bulbous twig blocking the drain intake. The water wasn't even making it into the drain! It was pooling, then pouring over the lip into the headliner, then pooling again at that corner. And I had removed the headliner (took me about 25 minutes) for nothing. A learning experience, anyway. So, if you've got a leak and you suspect the moon roof, first check up there. Open the glass and pop your head up there. The drains are holes about the size that would fit a pencil. - BenP.S. I have a 2003 Vibe, M&T (obvs)
keithvibe
Post by keithvibe »
If you want to your more than welcome to take a 2hr drive out to my house and we can drop your headliner in about 15mins and inspect your drain tubes
jake75
Re: Headliner Water Leak (keithvibe)
Post by jake75 »
This is why I have never been a fan of paying $1,000 for a hole in my roof. Not to mention the risk of a sunburn to the top of my head - not much cover left.
