Quote, originally posted by Sublimewind »Look up a few posts man, I was trying to help you out with the sub issue.. woops missed that, sorry!Quote, originally posted by Sublimewind »there are far to many "depends" to give you a proper answer man, sorry... if you could be more specific, maybe I can help... What sort of box are they in sealed/ported and how big? What are they? (the subs) and how are they wired (DVC/SVC, dual 4ohm coils..ect)what amp? At what point in a song does this happen? Is it just the VERY low notes?I'm not sure the measurments on the box, but you can check out the size and kind of get an idea of what I'm workin with in my garage:" TARGET="_blank">
http://forums.genvibe.com/zerothread?id=35580I'm not sure how they're wired, I don't really know much about them. If you explain it to me I'm sure I could figure it out.The amp is a 600 watt or 650 watt Sony Xplod. And this seems to happen on the more low notes. Like a longer note seems to not bump as much. The longer bass notes just don't sound as nice, do you know what I mean?Another thign it could be is the cold. The warmer my car, the better sounding I find it. It's pretty cold out recently, but it's warming up.Quote, originally posted by tribalman »hardware does matter a bit, but so do the settings. in my system the setting of the HU affect how the sub sound and so do the setting on the amp.  i'd say try retuning it. my HU has setting for bass, treble, and sub. the way i do it is i turn off the bass and off the sub. i tweak the treble until it sounds ok. i then turn on the bass. this is the bass that comes out the door speakers. i tweak it until the two sound good together. i add the sub last. i put the HU setting at the middle and then use the amp settings to tweak the sub sound. when i get it sounding ok i try a few different song styles to make sure they all sound good. Thanks for your help. I do tend to tune with my HU a lot, and I find myselfing adjusting the bass with every song. I just checked my HU again and I found some more settings to tamper with. I believe it's called HDU or something? I will check it out when I remember.Another problem I found is when I change the settings with my HU, my subs are unaffected by the subwoofer setting. I used to be able to make it sound better by tuning the subwoofer setting, but now the only thing that controls the subs is the bass setting.
