Don't know if the factory offsets are the same between 1st and 2nd gen Vibes... the 1st gen uses 2 OEM offsets. The OEM 16 inch steel and alloy wheels share +39mm offsets.The OEM 17 inch alloy has a +45mm offset. The 17 inch aftermarket alloys on my vibe have +38mm offsets.The 1st gen Vibe can generally fit wheels with offsets to +35mm to +45mm... depending on diameter and rim widthThe RTX Neurotoxins would look good on a Vibe or Trix.
Just talking to the guys a R. Thibert they're saying expect a big price increase for all mags and accessories this spring. All the pricing was adjusted for the CN$ being on par with the US$ last year now they have to adjust back for a weak CN$ again when they start getting their '09 stock. Guys at Fastco are saying the same thing. If you can find a set in current stock there going to be much cheaper than in a couple months when the containers of new stock come in.
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
