I hit a milestone
ajflan
I hit a milestone
Post by ajflan »
Well, it has finally happened. I just went over 100,000 miles in my vibe. Other than the awful grinding sound when I turn all the way to left, she's still running just fine. (Knock on wood)
February 08' VOTM Check out my Band! http://www.facebook.com/pages/...67945
ou.grizzly
Post by ou.grizzly »
What do you think is causing the grinding noise?
kunkstyle
Re: (ou.grizzly)
Post by kunkstyle »
Maybe it's that milestone he ran into?
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
ramenboy...
Post by ramenboy... »
congrats andrew!i'm at like 120k...L0NG LIVE THE VIBE!!!! i can't afford a new car yet
de-badged o4 vibe
o2 triumph speed four
ajflan
Re: (ou.grizzly)
Post by ajflan »
Quote, originally posted by ou.grizzly »What do you think is causing the grinding noise?I'm hoping it's just brakes or an easy fix like that. I don't feel like getting too dirty lol.
kunkstyle
Re: (ajflan)
Post by kunkstyle »
Have you checked the power steering fluid level?
ajflan
Re: (kunkstyle)
Post by ajflan »
No I haven't, but I don't think that is the problem though. You can feel the grind as well, and I know I need new brakes anyway. I think I will do brakes and see if that takes care of the problem. If not at least I will have fresh brakes!
808 Vibes
Re: (ajflan)
Post by 808 Vibes »
Yay...congrats on the milestone!
~ ALIS VOLAT PROPRIIS ~
brbo
Re: (HawaiiPontiacLover)
Post by brbo »
If it occurs while you are moving I'd guess the outter CV joint,, if brakes grind when applied it should happen regardless of the wheel position,,Hope it's not too serious,, Congrats !!Cheers brbo
vibolista
Re: (brbo)
Post by vibolista »
The milestone is A-OK, but any awful grinding is bad. Better take a chance at getting a little dirty and have a look at that corner soon. Hopefully it's not serious. 100,000 miles and looking mighty good!
ajflan
Post by ajflan »
Update: The grinding sound was just my engine shield. It was torn loose, probably from the ridiculous winter we've had so far, and was rubbing the wheels and junk. However, I still need brakes really bad.
Sublimewind
Re: (ajflan)
Post by Sublimewind »
If you wanna drive all the way up here, I have the garage (heated) and all the tools...
ajflan
Post by ajflan »
Thanks for the offer sublime, but I have the tools as well. I just have to do it in my freezing cold garage lol!
BlueCrush
Re: (ajflan)
Post by BlueCrush »
Congrats on the 100,000 milestone!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
