2009 2.4L mpg
ned23
2009 2.4L mpg
Post by ned23 »
Latest test with the 2009 2.4L 5-speed automatic gave me a trip average of 30.12 mpg on the highway. Car has a little bit over 2000 miles on it. I was kind of surprised at the pump, so I filled to the third click. Before the trip I changed the oil to Pennzoil platinum 5w-20 and put in some Lucas fuel treatment that I buy buy the gallon at truck stops. Gas was Costco 87 octane and Goasis 89. That's it. Post your mileage!Ned.
ned23
Re: 2009 2.4L mpg (ned23)
Post by ned23 »
I also should point out that I was helped by a stiff 20-25 mph tailwind on the way up and the fact that there were almost no trucks on the road - so, no lane changing, which eats gas. Weather was cold, dry, high pressure, sunny, mid-20s °F. Just about ideal conditions.
drscribner
Post by drscribner »
Does your 5-speed automatic reset to 1st gear at a dead stop?Thanks,
ned23
Re: 2009 2.4L mpg (drscribner)
Post by ned23 »
Quote, originally posted by drscribner »Does your 5-speed automatic reset to 1st gear at a dead stop?Thanks, I have no idea. To tell you the truth it often feels like it's starting out in second unless I give it lots of fuel. I'll have to watch the rpms and report back. I'm going out of the office this afternoon.
zoobernaut
Post by zoobernaut »
Please also post highway vs city and how often you use cruise control if at all.
2009 Vibe - 2.4L 5-speed - Blue Steel1993 Firebird Formula - 5.7L LT1 6-speed
ned23
Re: 2009 2.4L mpg (zoobernaut)
Post by ned23 »
24.2 for 75% City driving on last fill-up. 25% Hwy, mostly without cruise control.
zoobernaut
5 speed or auto?
ned23
Post by ned23 »
Quote, originally posted by zoobernaut »5 speed or auto?Yes. (it's the 5-speed automatic)
Firescooby
Post by Firescooby »
I'm VERY disappointed in my mileage. The BEST I've gotten is 28mpg and that was 100% highway, cruise, 70-80mph.My usual mileage is 25-26mpg, with 75% being highway. It's a stock 09 GT with almost 9k miles.
2009 Vibe GT - Hot Red Metallic2006 Chevy 2500HD 4wd Duramax/ Allison2005 Toyota Sienna LE1998 Honda Civic DX - SOLD
ned23
Post by ned23 »
Latest reading is 22.54 mpg. This is mostly moderate city driving (incl. short trips on and off expressways, not much stop and go), with about 25% heavy city including some wintry weather.
ned23
Re: 2009 2.4L mpg (Firescooby)
Post by ned23 »
Quote, originally posted by Firescooby »I'm VERY disappointed in my mileage. The BEST I've gotten is 28mpg and that was 100% highway, cruise, 70-80mph.My usual mileage is 25-26mpg, with 75% being highway. It's a stock 09 GT with almost 9k miles.I wouldn't actually say I'm "disappointed" but I was "hopeful" for a little better mixed / highway milage with a 4 cylinder. That said, for a car this size with over 150 hp, the mileage is pretty good by historical standards. It's obviously a lot easier to get 30mpg when you're only running 125 hp. You can get 40 mpg with a Yaris but it's only got 105 hp and is running at 85% load at 3800 rpms on the highway.
Eloi
Post by Eloi »
Here, with the winter lower quality gas, and the increased use of the heater cause it' s really cold, my mileage dropped from the usual 27-28 MPG to around 23-25 MPG (usual drive is about 75% highway 25% city).
2009 Vibe (2.4L) - Manual - Red Hot Metallic
ned23
Re: (Eloi)
Post by ned23 »
It seems like cold weather by itself shouldn't necessarily cause a major drop in highway mileage (in a fully-warmed engine) by itself. Cold air is usually denser and drier, which is better for combustion and your basic laws of thermal dynamics define efficiency by the difference between the operating temperature of the engine and the outside air. The bigger the difference, the more efficiency. IMO, It's more often the other factors like the fuel blends, different driving styles because of road conditions and increased time it takes the engine to warm up for shorter trips, people pre-heating their cars, etc., that cause the big drops in mileage. Of course if it gets really cold, then yes the temperature is a factor. Makes your oil thick, keeps your engine from getting warm enough, makes your tires stiffer, your gears stiffer, etc.
ned23
Re: (ned23)
Post by ned23 »
I've got a new low: 20.48 mpg. This was 148 miles of 100% city driving with a good bit of wintry weather and heavy traffic. Also pre-heated the car twice.ned.
ned23
Post by ned23 »
From Columbus, Ohio to Detroit to Auto Show, West to Dearborn Hts. for Dinner and back to just south of Toledo for fill-up. 2 passengers, winter weather, highway mixed:311 miles / 11.09 gallons = 28.04 mpg. Pretty much "As Advertised". How are other people doing?
Tubaryan12
Post by Tubaryan12 »
Quote, originally posted by Firescooby »I'm VERY disappointed in my mileage. The BEST I've gotten is 28mpg and that was 100% highway, cruise, 70-80mph.My usual mileage is 25-26mpg, with 75% being highway. It's a stock 09 GT with almost 9k miles.Your mileage is actually pretty good for driving that fast. If you want much better than that you'll have to either lighten your load or slow down.
ex Vibe: 2005 Abyss 2 tone base, auto, power package (33.24 mpg combined)2008 Kia Rondo EX V6 7 passenger Volcanic Red w/ tan cloth interior (26.7 mpg combined) Finally got 30 mpg combined on the Rondo V-6 (10.24.09) Smith Driving
SinisterMind
Re: 2009 2.4L mpg (Tubaryan12)
Post by SinisterMind »
My wife's AWD Matrix gets 26mpg highway (mostly highway with some city driving) at 70mph and 16mpg city. Her city driving consists of a 5 mile drive to work. It's also cold out and the car has 1500 miles on the odo.
Eloi
Re: (Eloi)
Post by Eloi »
Quote, originally posted by Eloi »Here, with the winter lower quality gas, and the increased use of the heater cause it' s really cold, my mileage dropped from the usual 27-28 MPG to around 23-25 MPG (usual drive is about 75% highway 25% city).I got new "lows"...Last 2 tanks were only around 22 MPG. But these were the coldest 2 weeks of winter so far (-30C regularly), so lots of "pre-heating"....
03vibedriver
Post by 03vibedriver »
I've just put 13,500 miles on the clock of my 09 2.4L auto Vibe and just gleaned 29 mpg mixed city and highway driving. My mileage keeps improving as I put more miles on the car.
lc9063
Post by lc9063 »
At 1st fill-up after 65/35 (City/Hwy) Avg 18.5 mpgAt 2nd fill-up after 15/85 (City/Hwy) Avg 25.2 mpgAt 3rd fill-up after 35/65 (City/Hwy) Avg 22.8 mpgSo far, have 954 miles on the Vehicle
Louis 2009 Carbon Grey Metallic AWD, Sun & Sound, 17" wheels, Theft deterent, etc.
Fisher
Post by Fisher »
Just clocked it last week at 31.9 mpg in Houston. Averaging say 63 mph on mostly highway.
'09 2.4L
Dog Hauler
Post by Dog Hauler »
I am averaging 28.5 to 29, mixed city and highway.
zoobernaut
After my first oil change, now up to maybe 6k miles. Ive played with different brands of gas and mixtures and so far think I found the best ratio for my particular vehicle.I am now averaging 29-33 with 2.4L 5speed manual with a mix of BP and Exxon fuel. Mostly highway driving. I still have not put in synthetic oil. That will be done before 7k miles. I will repost miles then.
imspace2
Post by imspace2 »
I'm going to try and stay off the throttle for a bit and see if my Exhaust/Intake combo makes any sort of improvement. Problem is intakes make you want to dig in. Check out my K&N post with pics and movie
Paragon
Post by Paragon »
Hmm... last fillup was 31.2ish.. before that was 31.4.. I have all the slips in the car. I know most if not all have been above 30mpg.I'm almost done with this tank and I have around 320 miles on it so far.. light has not come on yet (around 3 gallons left when the light comes on)Mostly highway traveling with some city 55-65 mph
RIT
Re: (Paragon)
Post by RIT »
What city do you drive 55-65 mph ? Certainly not NYC !
Paragon
Re: (RIT)
Post by Paragon »
har har
zoobernaut
Doesn't everyone drive 55-65 in the city? Esp on the BQR. Brooklyn Queens Raceway?
BIGJAMESCRU
Post by BIGJAMESCRU »
I only have about 450 miles, but I am averaging about 27.4 MPG city and highway.... I drive pretty fast, my average shift is 3500-4500 rpms... I drive about an 85-90 mile round trip everyday, averaging about 80-90 miles per hour whenever I can, so needless to say my driving is a little more aggressive than most.... I have been running premium though... what about you guys? I added a couple of pics of me at the pump last night...
BIG JAMES 05 Vibe GT- White (RIP)09 Vibe GT- Red Hot Metallic07 GMC Sierra SLT- Vortec MAX- Steel Gray06 Hayabusa Special Edition- White on Silver"Let Do The DEAL!!!"
zoobernaut
What % tint do you have?
BIGJAMESCRU
Re: (zoobernaut)
I have 35% on the driver, and passenger window's and 20% on the other windows.... Windshield is stock... 35% is the darkest legal on the front two windows in Texas.
Old Tele man
Post by Old Tele man »
...just got my '09 Vibe 1.8L/Auto and first tank fillup was 33.1 mpg, second was 33.6 mpg....am hoping for something closer to 36-38 mpg once she's fully "broken-in" engine-wise.
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
ned23
Post by ned23 »
My 2.4L highway mileage is steadily improving as the car breaks in. At 5,000 miles I'm logging between 28-31 mpg on the highway on trips of 90 minutes or more with two people.
ParknVibe
Re:
Post by ParknVibe »
With my 2009 2.4L Vibe (automatic with a roof rack). I am only getting 19 - 20 mpg during the month of May. This is mostly short local driving. I try to keep the speed within the speed limits. I just had my first oil change and I have just over 2100 miles on the car.I just had no need or time for long highway driving except for one on Thanksgiving. I was getting only 17 mpg during the past winter.
j42.snyder
Post by j42.snyder »
I finally managed to get the mileage it's advertised to! On my last tank I averaged 6.8L/100km (that's 34.6 MPG U.S.). About 85% highway, between 100 and 110km/h (62-67MPH) over 4 days. My car is a 1SB 2.4L auto, with 8,400kms on it. Factory rating is 6.9L/100km hwy.My best previous average was 7.2L/100km (32.7MPG) which I had hit a couple of times. I've used Shell V-power (91) for the last two tanks - and it has made a notable difference in the feel, as well as improved my average mileage compared to regular. It hasn't been especially warm this week either - so it's not just the weather.I figure I'll try this for another couple of tanks to set a good "baseline", and then move back to regular to see how much difference it makes. It could partially just be the change over to summer gas that's helping too - I'll find out.Here in Canada, that V-power contains no ethanol, which may also help somewhat. 87 contains up to 10%. Unfortunately we have to pay 13 cents/liter over 87 to get this (that's about 49 cents/gallon extra). Tonight I paid $1.08/liter ($4.08/gal) - a lot better than last summer when it hit around $1.48/liter. I hope this summer isn't quite that nasty.I'm just happy to finally get this mileage. My previous car (2002 Sunfire 5-speed 2.2 OHV) managed to set a record of 5.8L/100km several times during the summer months (40.5MPG) - while only being rated to get 7.0 hwy. Maybe the Vibe's just getting broken in finally. I had about 15,000km on the Sunfire the first time I hit that mileage (5.8). It could still repeat it last summer with over 230,000km on it too! It was a lot easier to "lug" though - being a manual. The automatic in this thing (Vibe) seems far too willing to downshift with even the slightest pedal movement. I'm sure eventually I'll get used to it.I didn't use cruise at all either during this week - and being cool out meant that the A/C didn't get turned on at all. I just left the transmission in "D" as well - under most conditions the "S" mode isn't manual enough for me to want to bother - so I don't.
RedHot_in_Bako
Re: 2009 2.4L mpg
Post by RedHot_in_Bako »
Our 16k mi. 2009 2.4ltr CA Emissions 5sp Auto is currently at the dealer again for poor City MPG, car consistently gets 15.2-16.1 MPG City driving and it's NOT driven hard, all flat ground surface streets, Highway mileage is 30-32 MPG, car is rated at 22/28 MPG, car gets Costco's 87 octane and gets filled to first click each time, Time before last fill-up City was 15.2, Weekend freeway trip got 32.2, next city fill-up got 16.1 I think I fall in the WORST Fuel Economy EVER for a Pontiac Vibe 2.4!, BTW...the worst I have ever gotten was 13.8 MPG when car had 1200 Miles on it. Does anyone know of someone else experiencing mileage this bad??
Re: 2009 2.4L mpg
Are you driving light to light to light with lots of idling? Carry much weight?
Does your coolant temp rise to normal? (A thermostat that's stuck open could prevent the engine from reaching normal operating temps.)
Do you drive with your left foot covering the brake pedal? (Wouldn't be the first time I've seen someone dragging their brakes)
Re: 2009 2.4L mpg
RedHot_in_Bako wrote: I think I fall in the WORST Fuel Economy EVER for a Pontiac Vibe 2.4!, BTW...the worst I have ever gotten was 13.8 MPG when car had 1200 Miles on it.
No doubt you are KING when it comes to the worst mileage. My 2009 Vibe GT, manual trans, gets an average of 27mpg (roughly 50/50 city/hwy driving) My best was 37.6 (all hwy) and my worst was 22.4 (winter time & wife drove it that week :roll: ) It is currently at just over 12k miles. There definitely has to be a problem. Maybe they can hook up some sort of monitor to the exhaust to detect your by-products and verify that your running rich or leaking it somewhere. Let us know what they find out
2014 Silverado, 2004 Vibe GT
j42.snyder
Re: 2009 2.4L mpg
Still pretty happy with mine for mileage. Click on the Fuelly link in my signature to see all my stats since new. Every single tank recorded!
Overall economy is only slightly worse than my previous Sunfire, which was a bare bones manual transmission car with no A/C or power anything (like SD's 1SA Vibe). My Vibe appears to consume about 30ml/100km more on average - virtually unmeasurable difference - only derived from long term statistics.
I'm sure if I get a tent trailer as I plan to in the next couple of years that will certainly hurt my average! I'm sure we'll have fun with it though, and I love road trips when I can afford to take them and have the time...
John
Re: 2009 2.4L mpg
RedHot_in_Bako wrote:Our 16k mi. 2009 2.4ltr CA Emissions 5sp Auto is currently at the dealer again for poor City MPG, car consistently gets 15.2-16.1 MPG City driving and it's NOT driven hard, all flat ground surface streets, Highway mileage is 30-32 MPG, car is rated at 22/28 MPG, car gets Costco's 87 octane and gets filled to first click each time, Time before last fill-up City was 15.2, Weekend freeway trip got 32.2, next city fill-up got 16.1 I think I fall in the WORST Fuel Economy EVER for a Pontiac Vibe 2.4!, BTW...the worst I have ever gotten was 13.8 MPG when car had 1200 Miles on it. Does anyone know of someone else experiencing mileage this bad??
Something is definitely not right. It's weird that you get decent highway mileage though. Do you put the transmission in drive or do you put it in shift mode? Having it in shift mode can hurt your gas mileage. When I first got my 2009 Vibe GT, I used to accidentally put it in shift mode all the time until I got used to how the shifter moves through the gears.
The combined gas mileage on my 2009 Vibe GT 5-speed auto over the last 18,725 miles is 27.8. The lowest mileage I've gotten is 23.0 and the highest (100% highway) is 33.9
