Timing belt change
VibeMike
Timing belt change
Post by VibeMike »
Does anyone know the general mileage a timing belt should be changed? I am over 100,000 miles with my original belt and I figure I am overdue for this change. I understand it is better to change it before it breaks on you--Mister Obvious!!!
Raven
Re: Timing belt change (VibeMike)
Post by Raven »
The Vibe has a timing chain.
No maintenance ever needed! It takes a lot of miles to screw up the chain.
jtnovibe
Post by jtnovibe »
Maybe he's referring to the serpentine belt? I didn't see anything in the owner's manual about when that should be changed.-JT
Raven
Re: (jtnovibe)
Post by Raven »
Quote, originally posted by jtnovibe »Maybe he's referring to the serpentine belt? I didn't see anything in the owner's manual about when that should be changed.-JTWhen it looks cracked or when it breaks, probably 100,000+ miles.
Re: (jtnovibe)
Yeah, they don't usually specify a service interval for drive belts... basically you just have to watch them and get them replaced when they become worn. If it is 100k on the original serpentine belt, do get that replaced...
VibeMike
Re: (ColonelPanic)
Post by VibeMike »
Yes I was referring to the timing belt/chain--I know some autos do have chains which last much longer--so I am glad the Vibes have chains not belts. However since I am over 100,000 on my original belts, I will have them checked soon. Thanks!
