those rims look good on the vibe... time for questions...why did you swap headlights?is that box by the shifter just for the leds?how much do those subie rims weight?
question #1 stock rim offset was +35the 2005 legacy 2.5 gt offset was +55question #2 i got the dash kit from wooddashexperts.comquestion #3 i swapped the headlights because i cracked the lens on the right side with a mailbox. so instead of ordering another 03/04 headlight i decided to go with the 06 headlight. which in my opinion looks way better on the car.question #3 yes the box by the shifter is just for the lights.question #4 the subie rims weigh 18 pounds
got the seat covers at meijers on sale. and to tell u the truth i am not big on lowering cars.now if it was a sports car like my dad s2000 then why not, but i dot think it looks good on the car
but with these cars they atually look better lowered IMO. we mean you dont have to go with a super low 2" drop, others on here went very little, 1"-1.5" drops and they look good. and with your suby rims it would look to bad lowered 1" and itd improve your handling
Those Subie wheels look great on your car. Where did you buy them from? What size wheel are they?
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
What steps did you take to remove the roof rack? I'm mainly wanting to remove the rails and put them back on after painting so I'm not wanting to tear anything up during the process.
actually the roof rack cracked, so i took it off, on the front part of the roof rack, ( the shiny plastic cap) they pop off and slide out, there should be 2 screws underneath it holding down the front part, same with the back gently lift the plastic cap up, and slide out, there should also be 2 screws holding down the rack, u will need to remove the screws with hex keys. i believe there are 2 more srcews holding it down, i think (not for sure) they are underneath the metal railing, it should just pop off,i plan on just putting on roof rack caps once after i get my roof painted
new pics, painted the roof black, vinyled the back hatch, door guards, and half of the spoiler, also got a new headunit, and 6.5 inch component speakers for the rear,this winter going to lower the car, put new front and rear sway bars, new shocks, and a strut tower brace. inside my soundstream rubicon 300-2 running my highs and mids my pioneer headunit
