This is a followup to an earlier posthttp://forums.genvibe.com/zerothread?id=35550I just installed the 9012 HIRPRICE: $52INSTALL: Easy. If you can get the stock bulbs out, thats the hardest part. (need small hands). Modifying the base of the HIR bulbs was easy, I used a dremel with a cut wheel. Took 5 minutes and I don't think I was overly precise. RESULTS: I don't notice a huge difference in the light output. I am not overly impressed. But I see an improvement. I drove home in the rain and didn't notice and refraction problems. See pics.CONCLUSION: If you need new headlights, these make a good replacement. If you want really bright upgraded lights, these aren't the solution.
