Well the recent problem I had as documented in http://forums.genvibe.com/zerothread?id ... d=35266was resolved after I replaced my spark plugs. Now I was wondering if anyone knew for sure that water was causing the problem or if it was the loose coil packs or a combo of bothHere's a photo of the stock plugs I pulled out and they are displayed in order 1-4 from left to right: Judging from the mineral deposits I must have had most of the water in #1 which would probably account for the misfire in cylinder 1 as per the CEL
