blown motor? whats the diference on the 1z and 2z motors
girlfriends 04 vibe
Post by girlfriends 04 vibe »
anybody else blow a 1z motor yet? my machanic is telling me that they have a 06 motor ready to go for it, is that the 2z? and is the Major diferenece between the two is the 1z G.M lower half with Toyota head and the 2z all Toyota? but i have also look at Chilton's online and saw that the value train is different on them what is the diferenece?
Re: blown motor? whats the diference on the 1z and 2z motors (girlfriends 04 vibe)
To put it briefly: Both are 100% Toyota. The 1zz is the engine in the base and AWD Vibes from '03-'08. A 2ZZ is a different beast entirely, the most significant difference being the valve lift feature and much higher output (horsepower-wise.) That engine was exclusive to the GT model which I believe was dropped after '06 or so.I think we've had people blow up both types of engines at one point or another.
girlfriends 04 vibe
Re: blown motor? whats the diference on the 1z and 2z motors (ColonelPanic)
thought the gt was a super charged motor?will the 06 drop into a 04? or better yet a 2z from a 1 z
Herb
Post by Herb »
Quote, originally posted by girlfriends 04 vibe »thought the gt was a super charged motor?will the 06 drop into a 04? or better yet a 2z from a 1 zI believe there was no super charged model. However GM did offer a super charger upgrade kit for the base model 1zz enginesThe GTs never had a factory super charger kit available
keithvibe
Post by keithvibe »
If you put in a 2zz you will also need the ecu. I think some have found that the base 5speed will bolt up to the 2zz. I don't think the 2zz will bolt up to the automatic.
psiu
Post by psiu »
Didn't the GTs come with a supercharger stock?
keithvibe
Re: (psiu)
Post by keithvibe »
Quote, originally posted by psiu »Didn't the GTs come with a supercharger stock?HELZZZZ NONo GT ever came with a supercharger, there wasn't one even made for the engine, unless you modified the greddy which was made for the celica
ramenboy...
Post by ramenboy... »
yeah the gt never had a supercharger. it was tuned differently, and put out about 170hp or so, same engine pretty much as in the lotus elise.the base engine with supercharger was boosted from about 130 to about 150hp. but like the guys said here, gt never was supercharged.
de-badged o4 vibe
o2 triumph speed four
IIRC the 2ZZ was high compression and also required premium fuel...
girlfriends 04 vibe
so her old blown 1z auto, could not get a 2z just dropped in it?I hope my machanic knows this!
northvibe
Post by northvibe »
1zz auto stock would not be able to have a 2zz swapped in unless you put a manual tranny in as well. Make sure to get a 1zz from a corolla, matrix, vibe or celica.
BlueCrush
Re: (northvibe)
Post by BlueCrush »
1ZZ......2ZZANY QUESTIONS?
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
prathman
Re: blown motor? whats the diference on the 1z and 2z motors (keithvibe)
Post by prathman »
Quote, originally posted by keithvibe »If you put in a 2zz you will also need the ecu. I think some have found that the base 5speed will bolt up to the 2zz. I don't think the 2zz will bolt up to the automatic.Some of the early Matrices with the 2zz did come with an automatic, but I'm not sure if it was identical to the one for the 1zz. Does anyone know?I have heard of switches between the 5- and 6-speed manuals, so those do seem to be compatible with both engines.Certainly easiest to replace an existing 1zz with the same engine type.
keithvibe
Re: blown motor? whats the diference on the 1z and 2z motors (prathman)
Post by keithvibe »
just tell your dumb mechanic to buy a 1zz... unless you want delays, problems and CEL'sI personally would love to drop a 2zz in to my awd... HAHAHA but i just don't want to deal with the headach
