Torque Wrench - 1/2" or 3/8" Drive?
Mojo72
Post by Mojo72 »
I'm thinking about getting a torque wrench and was wondering which size drive will get me the most use. Any suggestions?
2004 1.8L (1ZZ-FE) Vibe (Lava Red)16" Michelin Destiny tires
keithvibe
Re: Torque Wrench - 1/2" or 3/8" Drive? (Mojo72)
Post by keithvibe »
depends on what size most of your sockets are?I would say 3/8th would get more use and there are always the adaptors you can use to size up to 1/2in
Mojo72
Re: Torque Wrench - 1/2" or 3/8" Drive? (keithvibe)
Post by Mojo72 »
Most of my sockets are 3/8". My immediate concern is troubleshooting a shudder coming out of my front wheels when I brake. ehoff121 suggested checking the torque in my front lug nuts before moving to the rotors. So now I want to know whether its better to torque 76 ft lbs using a 1/2" drive or a 3/8" drive. How much can a 3/8" drive take? If a 1/2" is better for that job, then I think I can get a 1/2" to 3/8" converter to accomodate the majority of my sockets. What do you think?
keithvibe
Post by keithvibe »
my torque wrench is a 1/2in drive and when needed i size it down with an adaptor to 3/8th
Mojo72
Post by Mojo72 »
Sounds good. Thanks!
Digger
Post by Digger »
Mine is a 1/2 inch. reduce it to 3/8 when needed
Raven
Re: Torque Wrench - 1/2" or 3/8" Drive? (Digger)
Post by Raven »
Quote, originally posted by Digger »Mine is a 1/2 inch. reduce it to 3/8 when needed Same here.
harryyiii
Post by harryyiii »
The progress bar required 150# torque of the bolts, which you will only find in a 1/2" torque wrench. The 1/2 to 3/8' adapters work fine. If you have only one, I agree that it should be 1/2".
ehoff121
Post by ehoff121 »
Quote, originally posted by keithvibe »my torque wrench is a 1/2in drive and when needed i size it down with an adaptor to 3/8th+1 I bought a deep socket (1/2" drive) separately to fit the lug nuts.Sorry, I don't remember the lug nut size. The local parts guy let me take a few out to the car to try them out, though.
Mojo72
Re: Torque Wrench - 1/2" or 3/8" Drive? (ehoff121)
Post by Mojo72 »
If you happen to remember the socket size (english or metric?), great. If not, no big deal. Thanks again for the tip on the lug nut torque possibly causing the front wheel shudder. I'll let you know what happens with it.
engineertwin2
Post by engineertwin2 »
If I recall correctly, OEM lugnuts are 3/4" and any aftermarket tuner lugs are likely 19mm. Or I have it reversed I don't know.
northvibe
Post by northvibe »
Id go 1/2 then size down if needed. sizing up? never seen that adapter.
ehoff121
Post by ehoff121 »
It's a 21mm deep socket (hex pattern inside).I have the factory alloy wheels and an AWD, so you may want to double check that you have the same lug size.Good luck!
simmer9000
Post by simmer9000 »
I could be wrong but the 1/2" drive is normally in ft.lbs and the 3/8" drive is in.lbs so it depends on the application.. I think for lugs you's want the 1/2".. and then size down for other..Just to note, Canadian Tire Maximum Line is on sale 50% off torque wrenchs today ($124 on sale for $59). Picked one up today.
keithvibe
Re: (simmer9000)
Post by keithvibe »
lol little late to the game... almost 1year since the last reply. But thanks for chiming in.
Re: (northvibe)
Quote, originally posted by northvibe »Id go 1/2 then size down if needed. sizing up? never seen that adapter. I have it. From 3/8" to 1/2" and I have a 1/2" to 3/4"... Ah the useless stuff you can buy at Princess Auto!!!I have 1/2" drive Torque wrench. And all the tools I buy are 1/2". I never saw the point of buying a set with 1/4", 3/8", and 1/2" drive when you can buy it all 1 size. If you need something smaller, grab a wrench!
keithvibe
Re: (star_deceiver)
Post by keithvibe »
Believe it or not I use my 1/4" drive sockets and wratchet more than any of my others. I just find them more user friendly and they get in to places that a normal, say 3/8",10mm socket will simply because they have thinner side walls.
vibedrivermatt
Post by vibedrivermatt »
I first had a 3/8" which can do 0 to 100 ft/lbs but when I installed a rear sway bar I had to buy another 1/2" wrench that went up to 250 ft/lbs. It depends on what you need it for at the moment. Id say get the 3/8" drive wrench that goes up to 100 ft/lbs because it could be used on a lot more stuff. There aren't too many times you'll need to torque stuff down over 100 or 150 ft/lbs. Get one of each if you can! the bummer about torque wrenches is they're expensive for the nice brand names like snap-on but, sometimes cheaper wrenches will do fine. I've been wanting to have my wrenches tested for accuracy but, they do come with signed certificates showing they where tested at the time of manufacture. And the wrenches are supposed to be able to be used several times before needing to be calibrated.. Ohhh and make sure you read the instruction before turning or twisting any dials or adjusters on the torque wrench if your getting a clicker type.. I had a new wrench and I loosened the adjuster below the lowest setting. I found out your not supposed to do that after reading the directions..oopps!
Water boy
Post by Water boy »
We need a "Tool" sub forum.I've been 'renchin' for 40+ years.There is probably someone out there that has a trick that I never thought of or a tool that is more useful.With the Vibe being a more "younger" generation car, "old farts in training" like me could still be useful.
2008
47,891 Added new horns
69,036 Added sound deadening
70,395 Battery
Sublimewind
Re: (star_deceiver)
Post by Sublimewind »
Quote, originally posted by star_deceiver »I have it. From 3/8" to 1/2" and I have a 1/2" to 3/4"... Ah the useless stuff you can buy at Princess Auto!!!I have 1/2" drive Torque wrench. And all the tools I buy are 1/2". I never saw the point of buying a set with 1/4", 3/8", and 1/2" drive when you can buy it all 1 size. If you need something smaller, grab a wrench!You shop for tools and auto parts at a place called PRINCESS AUTO.... (as not not Prince?) Wow, you got a lot of women mechanics up there too... lol...
Sublimewind
Re: (keithvibe)
Quote, originally posted by keithvibe »Believe it or not I use my 1/4" drive sockets and wratchet more than any of my others. I just find them more user friendly and they get in to places that a normal, say 3/8",10mm socket will simply because they have thinner side walls.Same here... My 1/4" drive Snap-On set has done more work than I care to say.. lol..
Re: (Sublimewind)
Princess auto is the Canadian version of Harbor freight tools! And yes, we got some hotties crankin' wrenches up here!http://www.princessauto.com/Here's the adapter set! http://www.princessauto.com/vm...r-set
Sublimewind
Re: (star_deceiver)
Quote, originally posted by star_deceiver »Princess auto is the Canadian version of Harbor freight tools! And yes, we got some hotties crankin' wrenches up here!http://www.princessauto.com/Here's the adapter set! http://www.princessauto.com/vm...r-setThat's awesome...!! I honestly have had thoughts of starting an all women run auto shop... everyone front t o back would be women (besides me ) I think women would LOVE something like that..
Re: (Sublimewind)
Quote, originally posted by Sublimewind »I honestly have had thoughts of starting an all women run auto shop... everyone front to back would be women (besides me ) I think women would LOVE something like that.. Men would be taking the car in for service for every possible rattle every other day... $$$ out the yingyang!!!!
