How do you disable 09 DRL
v329799
Post by v329799 »
Have 09 Vibe AWD and I hate DRL I would like to either disable them So I know I don't have any lights on or turn them on all the time when engine is on. According to manual you should not do this. With our old Prizm I put a covering over sensor on dash Lights on all the time. Tried doing this on new Vibe Sometimes they were on and other times just DRLWhat gives??????
keithvibe
Re: How do you disable 09 DRL (v329799)
Post by keithvibe »
This is for the '09 Corolla - May help you, Do it at your own risk since I do not own a '09 vibe..1) Remove the glove compartment2) Locate the DRL module. Its a black unit mounted sideways with a wiring harness plugged in the side of it.3) Unplug the harness from the module4) Cut the blue wire at pin 12. Leave at least 3 inches of wire sticking out of the connector in case you ever want to put it back.5) Tape up the end of both blue wires.6) Plug the connector back in.7) Put the glove box back.8) Enjoy the freedom of controlling your lights yourself.
v329799
Post by v329799 »
Thanks I just may do that the next free weekend I have.the way its going may be Thanksgiving weekend
