I have ordered a 09 vibe... some day it will come. I am looking at light mods as I drive on back roads a lot at night. $50 a set for Silverstar Ultra or so at the local store. and tehre are 3 sets needed. Now if I go with HID the best cheap ones I have found are $150 plus shipping. Worth the cost if I did all 3 sets I would be.... well broke I guess that is big bux... please let me know your thoughts
Once you go HID, it's hard to go back. I had them in my Grand Prix and now that I am back in my Vibe with Halogen, i'm hating it!! Just a matter of saving money to get them. IMO, they will be well worth the investment as long as you are getting them from a good source.
Basically, with HIDs you will always have a glare issue unless you are retrofitting a projector housing in there. The best thing to to is minimize the glare for oncoming traffic. You have have to adjust the headlamps some, but just make sure they you have minimized the glare to oncoming traffic, but still making it useful to yourself.
Quote, originally posted by Racemedic »Am I going to need to worry about aiming problems or glare... and if I do what will I have to do... I direct drop in would be bestyes you will definitely have glare since the reflector housing isn't designed for hid's. like stated by wolfman the best is to do a projector retrofit. i had tsx projectors retrofitted into my old car's headlights and they were great. i think i've gone thru over 6 retrofits testing out different projectors in the past 3-4 years. but anyways, you should save up for a projector retrofit i will rather stick with the halogens until i get a retrofit...never again will i put aftermarket hid kits into halogen housings...it's retrofit or nothing =Pactually on the 09's the headlights aren't that bad...not as bad as i thought. turn on the fog lights and it's plenty bright.
with HID's in my ms3 now, I would NEVER go back to plain bulbs...EVER. Aiming in mine are just like bulbs, I turn a screw driver and they go up and down, but I am not sure about aftermarket kits, make sure you research the brand before you purchase them.
I went thru so many silverstar bulbs in the Vibe, it would have been the same for 2 sets of HID's. and all you need to get are 35W bulbs and you shouldn't have an issue with the housing. It's not necessary to do a retrofit (though it looks very nice). I bought mine for the LGT at http://www.apexcone.com. Super cheap and pretty good quality.
