03 and 05 vibe
vibe11
03 and 05 vibe
Post by vibe11 »
is the o3 Pontiac vibe headlight assembly compatible with the 05 vibe headlight assembly?
BlueCrush
Re: 03 and 05 vibe (vibe11)
Post by BlueCrush »
Quote, originally posted by vibe11 »is the o3 Pontiac vibe headlight assembly compatible with the 05 vibe headlight assembly?I believe it is, but others should be able to confirm that. I considered swapping out my '05 headlights with a set of new '04s but they cost too dang much new and I would only want new if I were to replace them.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
vibe11
Re: 03 and 05 vibe (BlueCrush)
Post by vibe11 »
i hit a mailbox last year. it just ran out in front of me so now i have enough money saved up to fix it. i currently need a hood new or used. and a right passenger headlight assembly.
BlueCrush
Post by BlueCrush »
Well the '03-'04 headlights are black and chrome and the '05-'08 headights are all chrome. So unless you are wanting to switch out both headlights get the same as your left one.
My Fleet:
vibe11
Post by vibe11 »
if i got two 05 headlight assemblies will it still mount up two the 03 brackets and bolt pattern?
vibe11
Post by vibe11 »
thanks for the info just saved me alot of money just ordered two right and left 06 headlight assemblies!!
