Plastic fastners/shop manual
Beemer
Post by Beemer »
How do you release/remove the two plastic fastners that hold the rear of the plastic engine (head) cover without breaking them?Has anyone published an after market shop manual for a 2005 Vibe?
keithvibe
Re: Plastic fastners/shop manual (Beemer)
Post by keithvibe »
the clips your talking about are just pressed in... simple door trim removal tool takes care of those or a flat head scewdriverYou won't find a repair manual in the store. However you can down load the manual in PDF format from http://www.Matrixowners.comGo the the main page on the center of the main page there is a link to down load the manual your talking about. The link will take you to http://www.megaupload.comOnce there enter in the code in the center of the screen in the code box... wait 30 to 60 seconds and then the download will begin.
Quote, originally posted by Beemer »How do you release/remove the two plastic fastners that hold the rear of the plastic engine (head) cover without breaking them?The first time I took that ccover off I broke both of the plastic fasteners, and never replaced them. I forget that there used to be fasteners there.
